There was a thread recently that concerned blow by and smoke coming from someone's oil filler tube and cap. In the discussion someone said that he needed to clean out the out exhaust that is on the side of a 223-6 engine because it might stop up and cause the burned fumes to not be able to exit properly.
I have located the pipe of the side of my engine (223-6) and have removed the bolt from the round cover, BUT, my question is:
How do you remove the round plate in order to clean it out?
I failed to subscribe to that thread and now I cannot find it, can anyone help?
You should be able to find that thread by going to the bottom of the page and click on
''next thread'' untill you get to the page the thread was on, keep clicking ''next thread''
till you find the page, hope this helps..seems like it is probably a page or two away?
