HELP!! Tie rods don't fit
Old Dec 30, 2011 | 05:40 PM
73 hi-boy 428 fe's Avatar
73 hi-boy 428 fe
OK Guys,
I have 73 hi-boy that I swapped in a 76 front end for the disk brakes and power brakes along with adding the power assist. The tie rods that are suppose to work are to small. Go all the way up into the steering knuckle with no resistance at all. I mean all the way up with no dust cover on ether. What gives? Do you think I have 78 or 79 steering knuckles on a 76 low pinion axle? Is so and I get new tie rods for the 78-79 will the power assi
Old Dec 30, 2011 | 07:12 PM
HIO Silver's Avatar
HIO Silver
Well, I think you're running in the same issue that I encountered when retrofitting 79 Bronco linkage and integral PS on my 73 with the drummed D44. The later disc D44 use thicker tie rod shanks and the steering arm holes on the early drum knuckles needed to be reamed in order for the Bronco linkage to fit.
Your situation is reversed... a later disc axle with the early tie rods. Therefore, I believe you need to use the tie rods for the 76 axle.
ford_pickup
Sep 19, 2011 12:17 PM
sc00ter
Jun 1, 2011 09:37 AM
talbotmatt
Nov 21, 2006 05:08 AM
blueoval66
May 30, 2005 07:53 PM
