Leveling kit
Old Dec 30, 2011 | 01:40 PM
crapr6's Avatar
crapr6
Leveling kit
Hey guys, I would like to put a leveling kit in the front of my 99 f350 dually cc diesel. I have seen many kits and ways of doing this. What is the best way of leveling the front end on my truck. What kit and way. Thanks for the help.
Old Dec 30, 2011 | 01:53 PM
bulla's Avatar
bulla
I just added the one leaf that levels the front. Cheap and easy. Haven't had any problems "yet"! My .02
Old Dec 30, 2011 | 01:58 PM
crapr6's Avatar
crapr6
Where did you get them from? I have seen shackle leveling kits, add a leafs, etc. just wondering what the best way to do this.
Thank you
Old Dec 30, 2011 | 02:02 PM
brushfit's Avatar
brushfit
does that not require some ball joint adjustment?
Old Dec 30, 2011 | 03:39 PM
crapr6's Avatar
crapr6
Ball joint adjustment. What are you talking about. We don't have adjustment on our ball joints. Must be a joke?
Old Dec 30, 2011 | 03:41 PM
crapr6's Avatar
crapr6
Unless you mean camber sleeve which I don't think is need for a leveling kit.
Old Dec 30, 2011 | 04:22 PM
Bob Taulbee's Avatar
Bob Taulbee
Duct Tape Tech.
It is only needed on 2 wheel drive trucks, 4 wheel drives have different suspension. On 2 wheel drive trucks you add a spacer under the coil spring to level it. That changes the camber and it needs to be adjusted
Old Dec 30, 2011 | 06:00 PM
crapr6's Avatar
crapr6
Oh ok. Didn't know what he was talking about. I have a 4x4.
Old Dec 30, 2011 | 06:08 PM
BlueScab's Avatar
BlueScab
I just put a 2 inch shackle kit on my truck. Still rides the same, but if I did it again I would just get the 3 inch icon shackle kit from Riff-Raff.
Old Dec 30, 2011 | 06:11 PM
bulla's Avatar
bulla
So I'm assuming it's 4x4 then? There are pluses and minus to each option. Add a leaf-very easy and in expensive. Eventually will sag and tend to be rougher.
Replacement spring pack- more money with a better ride.
Drop bracket is about the same price as new springs and maintains the original ride. Advantage is your not wasting money if you ever want to go bigger. Downfall is I haven't seen one any lower than a 3 1/2" so you would actually be a lil high and need a new trac bar or relocating brackets. I just went with cheap and easy!
Old Dec 30, 2011 | 06:14 PM
bulla's Avatar
bulla
On a side note weather it be 2x4 or 4x4, anytime "I" do any modifications to the front end of a truck going up with it or down with it or even just as much as changing wear parts, I always have it checked and adjusted for a good drive! this is key!
Old Dec 30, 2011 | 09:08 PM
crapr6's Avatar
crapr6
Cool, thanks for the info. I was looking at longer shackle kits and was kinda liking that way of leveling it. I seen the mini leaf pack and to me that looks like more or less a block your putting onto of the front axle which I always heard is not good to do on the front axle.
Old Dec 30, 2011 | 10:56 PM
HD Rider's Avatar
HD Rider
I have the longer shackles on mine. They can be had for almost half the price of the add-a-leafs.
Here they are. F250 1999-2007 Ford SD 1.5 inch Front Lift Shackles | Jack-It, The Suspension Experts
Old Dec 31, 2011 | 07:26 AM
bulla's Avatar
bulla
This is what I was referring to. Wasn't aware of just the shackle kit. How is it working for you?
http://www.shopwiki.com/_Fabtech-3.5...97187&s=760035
Old Dec 31, 2011 | 07:50 PM
HD Rider's Avatar
HD Rider
The shackles are working great for me. Those Fabtech spring mounts are spendy.
lombardo96
Feb 16, 2006 08:39 PM
99stroke
Aug 20, 2003 04:13 PM
