Sponsored by: Auxito
Cruise Control
Old Dec 30, 2011 | 01:18 PM
tomfiii's Avatar
tomfiii
Cruise Control
Hi, Got a 1999 F250 Super Duty Speed control inoperative. Went thru control test, light flashed correctly and no codes ,but throttle did not move/took cable off servo and servo wheel barely moves after doing test,supposedly it's not supposed to move much. Went thru voltage and ohm flow chart test and got to if speedo works check circuit 679 ,but it checks 0k. When I activate speed control the light comes on and thats all, also if I hit the brakes the light goes out. Anybody have any idea whats wrong with my speed control?
Old Dec 31, 2011 | 10:20 AM
fordiesel69's Avatar
fordiesel69
A super duty belongs in a different forum, and what year are we talking?
Often the buttons on the sterring wheel get gunk in them. You can also pull the module off the top of the servo and have a look for burning, or for stripped teeth on the servo gears. Sounds like you covered everything electrical.
Old Jan 2, 2012 | 11:30 AM
tomfiii's Avatar
tomfiii
Thanks ,pulled top and all looks ok ,corrected to be a 1999, whoops should be in Super Duty and Heavy duty thread.
Old Jan 25, 2012 | 11:50 AM
tomfiii's Avatar
tomfiii
fixed
Swapped in used unit from another vehicle and now it works.
dexterous
Jan 2, 2022 02:51 PM
madsen203
Jan 24, 2019 10:01 PM
tomfiii
Jan 25, 2012 09:07 PM
tjbeggs
May 15, 2009 01:03 PM
Lanny Sutton
Sep 11, 2005 09:33 AM
