Hard starting
Old Apr 17, 2003 | 03:50 PM
petem's Avatar
petem
Hard starting
hello-
My '76 f250 with 360 - 2V has starting problems. If the truck sits for a few days it takes several cranks before it fires. I replaced the accelerator pump diaphragm, but that didn't solve the problem. Could fuel leak into the intake eventually leaving the carburetor dry? Any ideas?
Old Apr 17, 2003 | 07:44 PM
73Custom's Avatar
73Custom
Hard starting
Once you get it started, does it start okay later the same day? A hot motor will heat the carb and boil the fuel out, so there is none for the next start-up. The easiest cure for this is a plastic carb spacer, worked for my 390 with perculation problems.
Marty
Old Apr 17, 2003 | 09:59 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hard starting
Ditto!
Old Apr 18, 2003 | 11:18 AM
petem's Avatar
petem
Hard starting
Sorry-should have clarified that. Yes-starts very easily same day (any temp) and even the next day.
Old Apr 18, 2003 | 08:11 PM
78 4X4 Thunder's Avatar
78 4X4 Thunder
Hard starting
I had the same problem with the big 3. I had a gas leak in the tank, so I replaced it and put on a after market fuel filter, like $2 and took out the one on the sender, tightened up all the Vac lines and the carb lines and fuel lines. Might just be your fuel draining back to the tank after it sits, so check all your lines, hope it helps!
Old Apr 20, 2003 | 02:25 PM
73Custom's Avatar
73Custom
Hard starting
Then it sounds like your fuel is draining back out of the carb. Could be due to a bad float, bad needle-seat valve in carb or bad fuel pump or combination of all.
Marty
