well the transplant is 95% complete....she fired up today Video :: VIDEO0004.mp4 video by Joeyd61 - Photobucket
havent drove her yet but will about lunch tomorrow,have to fix antifreeze leak at thermostat,mount bumper,tires and grill...
Sorry to hear. You might want to start a new thread on the cracked front cover. IIRC if you use the wrong combination new/early cover and incorrect gasket that can cause it to crack.
the cover and reservoir are off a late 99-03..the only thing used off the e99 is the block,crank,rods and heads...the overhaul kit is for the late 99-03....
Boy, I can't believe it leaked if it didn't before. Talk about bad luck. Well good luck and keep us posted on the repair. I would try and take it off to repair,weld, but if not I wish you luck.
If welding it doesn't work, I'm sure you know what the "option B" is....
Update, option B it is....motor has been removed,front cover replaced with new one,set it back in last night and hope to have it running tomorrow....
picture of motor out the second time
