Hello everyone, I am new to the forum and cannot find an answer to my question. I have a 92 bronco that has a problem running in the cold weather. When it first starts it sounds as if it is running on 5 or 6 cylinders. As is warms up it will sound more like 7 and then finally it will smooth out. I have replaced the the egr valve recently. Does anyone have any suggestions on how to fix this? Also, I took a toothbrush and cleaned the throttle area.
Thanks for your help.
Bayouvol
Start by running the self test. Be sure an post which test an results are from IE; "KOEO" "CM".
If you get a "system pass" for both those then run the KOER test see if it returns anything, no need too yet if KOEO test returns issues, those would need corrected before moving on to KOER test.
