limited slip upgrade
Old 12-28-2011, 08:25 PM
73FOMO's Avatar
73FOMO
73FOMO is offline
Well...I could easily do in 2 hours, but I am sure they will charge for the rear diff fluid, gasket, and shops supplies. I would guess $225 if you pay someone. I think you will be fine with the ford diff and spacers. You could rock the gear back and forth and feel for the amount of backlash and compare. The carrier should have 0 play side to side after shimming.
Old 12-28-2011, 08:34 PM
jokerforever's Avatar
jokerforever
jokerforever is offline
Originally Posted by Diesel_Brad
You are in over your head. take it to someone who knows what they are doing, or you will end up blowing the rear end
Don't let the naysayers scare you. How can you learn if you don't try? Read up, ask questions, look at pictures on the web, watch a YouTube vid or two, ensure you have the tools and time and we'll be here for back up. Axle work isn't the black magic that a lot of folks make it out to be and just replacing the carrier in an 8.8 is a fairly simple job. You just have to know what you're doing. Learn by doing.
Old 12-29-2011, 06:09 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
I have done multiple gear changes and carrier swaps, but i am also an ASE mechanic. For the most part it is pretty straight forward. BUT, if you do it wrong, it will grenade the whole rear end. and then you will be out alot of money. It is NOT as simple as just bolting the new carrier in. You need to check preload, and back lash. Both of which have to be PRECISE. There is a reason shops charge 500+ to do it
Old 12-29-2011, 07:50 AM
Edgethis's Avatar
Edgethis
Edgethis is offline
I'm glad the local hot-rod shop is only charging me 250 an axle to fully rebuild and install a LS. Granted thats all labor, I have to supply the parts.
I agree with Brad here, I have thought many times about doing this myself, but it is a very costly mistake. If you know a friend that can do it, invite them over and share some beers. They can watch and help you out maybe.
Old 12-29-2011, 09:30 AM
Diesel_Brad
There is a good idea too
Old 12-29-2011, 09:33 AM
bruno2's Avatar
bruno2
bruno2 is offline
You tube is loaded down with videos on how to do it on 8.8's. I just swapped in an LS carrier myself and it fit perfectly. preload and back lash is important , but , just having some is usually enough when dealing with old used gears. I have a couple of buddies that specialize in gear work. One of them has been doing it since the 60's and the other is his understudy of about ten yrs. I have never seen either one of them use a dial indicator or a torque wrench to set one up. They do it by feel. Now doing it for as long as they have sort of qualifies them as experts on how one should feel, but , as long as it goes back in with a little bit of backlash it will be OK.
Old 12-29-2011, 09:38 AM
bruno2's Avatar
bruno2
bruno2 is offline
Now here is the rub. You will have to swap your ring gear onto the new carrier. The ring gear will need to be heated up pretty thoroughly before it will go on straight to the new carrier. This requires an oxy-acetalene torch. If you dont heat it the ring gear will never go on straight and this will cause it to wear out faster than normal and may very well cause some gear noise too. A lot of people do it w/o heating it up , but , they usually never go on straight and its hard to tell with the naked eye if its slightly out of kilter.
Old 12-29-2011, 10:37 AM
Phy's Avatar
Phy
Phy is offline
Here's a pic of someone checking backlash:
http://www.google.com/imgres?q=ring+...QxYDXAQ&zoom=1
I'd check the contact pattern before teardown, and make sure it's the same after re-assembly. Used gears will wear in to each other, and can howl pretty badly if the contact pattern changes much...
Old 12-29-2011, 10:48 AM
Edgethis's Avatar
Edgethis
Edgethis is offline
<A href="http://www.google.com/imgres?q=ring+gear+backlash&hl=en&sa=X&biw=1250&bi h=869&tbm=isch&prmd=imvns&tbnid=pdjZ1Nr4QDfnwM:&im grefurl=http://pirate4x4.com/tech/billavista/<acronym title=" Ranking? Page>PR</ACRONYM>-ARB/articles/14b_Gear_Setup/&docid=7pMVTVdsU3f-xM&imgurl=http://pirate4x4.com/tech/billavista/<ACRONYM title="Page Ranking">PR</ACRONYM>-ARB/articles/14b_Gear_Setup/IMG_3870_small.jpg&w=400&h=300&ei=DpL8TvmJMaPgsQKQ xYDXAQ&zoom=1" target="_blank">http://www.google.com/imgres?q=ring+gear+backlash&hl=en&sa=X&biw=1250&bi h=869&tbm=isch&prmd=imvns&tbnid=pdjZ1Nr4QDfnwM:&im grefurl=http://pirate4x4.com/tech/billavista/<ACRONYM title="Page Ranking">PR</ACRONYM>-ARB/articles/14b_Gear_Setup/&docid=7pMVTVdsU3f-xM&imgurl=http://pirate4x4.com/tech/billavista/<ACRONYM title="Page Ranking">PR</ACRONYM>-ARB/articles/14b_Gear_Setup/IMG_3870_small.jpg&w=400&h=300&ei=DpL8TvmJMaPgsQKQ xYDXAQ&zoom=1
Thats a great link!
Old 12-29-2011, 09:48 PM
Boilertwinkie's Avatar
Boilertwinkie
Boilertwinkie is offline
Whatever you do take your time and be patient your first swap<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Jerepcb
1997 - 2003 F150
03-04-2018 05:32 PM
prisoner of gravity
Ontario Chapter
06-16-2008 06:53 PM
famousbassist1
1983 - 2012 Ranger & B-Series
03-16-2005 05:24 PM
Ant50
04-22-2002 01:12 PM
Quick Reply: limited slip upgrade
