Sponsored by: Auxito
misfire
Old Dec 26, 2011 | 10:42 PM
Louie3's Avatar
Louie3
misfire
2001 F150 Screw 5.4
Ok well I have a misfire on 3&8. I changed the spark plugs and coils on both of them. And cleared the code. Turned on the truck and it still sounds the same. I can feel the truck vibrate when I'm driving but between 40-54mph the truck shakes like hell and you have to give it gas all the way to 55 for it to feel "comfortable". I have no clue what it could be. I'm not missing on any other cylinders.
Old Dec 27, 2011 | 01:37 AM
Bluegrass 7's Avatar
Bluegrass 7
Simple; you have more faulty coils.
The speed you gave is the give-away to the issue.
If cylinders 3 and 8 are not setting codes you got thoses but there are others.
Change the rest or you will be hunting them down because they don't set codes for you to see. They are missfires for a different reason.
Good luck.
Old Dec 27, 2011 | 01:54 AM
Louie3's Avatar
Louie3
So you think the other coils are giving me a problem? I got a check.engine light for 3&8 again after I cleared it. When I was driving the CEL was flashing then stopped but stayed on. Guess I gotta buy me some coils tomorrow :-(
Old Dec 27, 2011 | 12:20 PM
Bluegrass 7
If you got 3 and 8 again after replacing coils and plugs, tell how you are doing the job.
You need to grease inside and ends of the boot tips for two reasons.
One to help seal the area and second to allow the boot to 'auto find' the plug tip and set down on it easy without cocking to the side and allowing the voltage a path to the head.
The flashing was telling you that there was no ignition and the cylinders' are passing raw gas to the cats that can burn in them causing them to melt, then you can have real issues with cost and labor.
Be sure the connector are seated on the coils.
Good luck.
jmbobs
2009 - 2014 F150
Sep 11, 2017 07:52 AM
damnford101
1997 - 2003 F150
Jul 14, 2010 03:04 PM
Ford-Trucker84537
Mar 12, 2009 04:54 PM
sprinklerguy
1997 - 2003 F150
20
Mar 19, 2007 09:57 PM
Black 5.4L
1997 - 2003 F150
Feb 27, 2003 07:50 PM
