4wd system
Old Dec 25, 2011 | 06:23 PM
Butl85's Avatar
Butl85
4wd system
I just bought an FX4 and pick it up tommorow. Just had a question for you knowledgable guys here. When you are in 2wd does the whole front end spin like the axles? Or does only the wheels spin when you are in 2wd? Reason I am asking it seems like with chevy the whole front end spins in 2wd.
Old Dec 25, 2011 | 06:30 PM
efx4's Avatar
efx4
The front axle shafts and front main drive shaft rotates all the time, but the transfer case sends power to them only when 4x4 is engaged.
Old Dec 25, 2011 | 07:14 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
no
Ford does not employ this system. Nor have they since the 80's...if even longer
The front hubs are vacuum UNLOCKED while you are driving around. The t-case is in 2wd only. The front axle and driveshaft are STATIONARY during normal driving
edit: unless you happen to have an AWD truck. Far as I know though, they 08 Limited was the only AWD F-150. Maybe a newer 09+, but I haven't seen one
Old Dec 25, 2011 | 11:23 PM
breezy5000's Avatar
breezy5000
Originally Posted by Tylus
no
This is correct
Old Dec 26, 2011 | 08:11 AM
cdmm151's Avatar
cdmm151
My 2011 FX4 forward shaft is locked in and spins while moving that means the pumpkin is engaged to the front wheels. Chevy did this for 2-3 years around 2003 then changed it where the shaft was not engaged. That only made since. Why have parts engaged and spinning for no reason. That only wastes fuel and power. Ford needs to do the same.
Old Dec 26, 2011 | 11:40 AM
rgmiller32's Avatar
rgmiller32
On my 2011 xlt the frt. shaft does not turn when in 2 wheel drive. If you jack the front of the truck up and turn the wheel with the engine off the half shaft and drive shaft will turn. Start the truck and let the vacuum built and the frt hubs should disconnect and only the wheel should turn. The half shaft should not. The vehicle has to be running or have stored up vacuum to release the frt hubs. My 2006 had a bad hub and would not release fully and cause a vibration and higher level of drag when driving.
Old Dec 26, 2011 | 01:32 PM
cdmm151's Avatar
cdmm151
RG, you are right. I went started the truck and the front shaft will turn by hand. Turn off the truck and it locks back up.
Old Dec 26, 2011 | 06:35 PM
F TOO FITTY's Avatar
F TOO FITTY
I knew it wasn't engaged while running, but I didn't know it was vacuum controlled. Another thing I learned on FTE!
Old Dec 26, 2011 | 07:17 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
Click here to show your appreciation
Crd16
1997 - 2003 F150
Aug 19, 2016 03:41 PM
h2ofowlhunter76
Offroad & 4x4
Jul 24, 2013 08:01 PM
Ian123
Aug 28, 2012 08:52 AM
2jhanna
Aug 6, 2007 09:38 PM
Dave85zxt
Jun 30, 2005 10:19 AM
