Think I blew fuse 22. I thought I read a while back that you can switch fuse 22 with another fuse just to check if you right. Which one is it if u can.
I think you're thinking of the PM relay, not the fuse. You can swap relays with the horn relay but I don't know of anything you could swap the fuse for.
If fuse # 22 is bad, replacing it with another fuse may not solve the problem. DIY mechanic suggested unplugging the fuel bowl heater first before you put in another fuse. I made a jumper of #12 wire to see if the engine would start after unplugging the FBH. It started right away. The replacement fuse burned out right away before I disconnected the FBH.
