I have an 89 bronco with 302. The fuel pump turns on and runs but not shut off. turn the key on and it will run continuosly for ever. I replaced the relay and it did not cure the problem. It has pressure, it will shoot out of the schrader valve and hit the ceiling. what could it be.
I don't know anything about your rig but I would think that that relay is hooked to some fuel pressure regulator or sensot that tells it when to turn the pump on or off. Maybe replace that or make sure it's hooked up and working???
There's no sensor - the computer controls the relay by switching its ground off & on, so diagnose that relay's ground wire for a short to ground. It should run straight to the computer. Check the wiring diagram in the Haynes manual.
there is also a 2nd relay . the EEC relay under the dash and should be near the processor. This energizes the fuel pump relay, so it could stuck as well.
I am not quite sure what you are saying about it not shutting off. I am assuming you mean when you turn the ignition to the on position that it runs until the ignition is turned to the off position whether or not the engine is running. Normal operation is when you turn the key to the on position it should run for a couple of seconds, then shut off. When the vehicle starts then it should stay on as long as the engine is running. It should then shut off after the engine quits running. There is a jumper that is shown in the haynes manual that will make the fuel pump stay on so you can test fuel pressure. Make sure that it is not shorted or grounded. I am not sure how the fuel pump on the fords know how to stay running while the engine is on, but I know some cars use a oil pressure switch that turns the fuel pump off when it senses 0 oil pressure and on with positive oil pressure. If ford uses this, which I am not sure, then maybe this sensor is bad.
Hi Smiley, as a bearer of bad news. I think you have a short some where that is suppliing power to the pump circuit. I have the same problem now. Discontect the battery ground and it stops. I'm waiting for warm weather to start searching for it. I suspect mine is somewhere between the firewall and the safety-neutral switch.
Bruce (Big Red Bronco, with a cracked head and wiring problems)
