Sponsored by: Auxito
temp sending unit?
Old Apr 16, 2003 | 09:24 PM
Locry's Avatar
Locry
temp sending unit?
greetings!!!
this is an awsome site, too bad i just found out about it. we've had the truck for 3 yrs or so. we've had it serviced a number of times at the dealership. i should've consulted this site before allowing those jerks to mess with our truck... anyways...
where is the temp sending unit located? the gauge fluctuates from normal to full(overheat). i'm guessing its a loose connection or something.
thanks guys
Old Apr 16, 2003 | 10:04 PM
LxMan1's Avatar
LxMan1
temp sending unit?
What engine does it have in it?
Old Apr 17, 2003 | 01:35 AM
Locry's Avatar
Locry
temp sending unit?
oh yeah, i forgot.
it's an xlt. a v-6
Old Apr 17, 2003 | 09:29 AM
Racerguy's Avatar
Racerguy
temp sending unit?
The temp sender is in the intake manifold, right behind the thermostat housing. It probably needs to be replaced.
Old Apr 17, 2003 | 09:41 AM
Bob Ayers's Avatar
Bob Ayers
temp sending unit?
There are 2 sending units close together. The one for your temp
gauge has a single wire connector, this is the one you want to
change. The other sending unit has 2 wires, this is the coolant
sensor for the PCM.....
Old Apr 18, 2003 | 02:41 AM
Locry's Avatar
Locry
Talking temp sending unit?
cool, thanks
Old Apr 18, 2003 | 11:02 PM
Locry's Avatar
Locry
temp sending unit?
uhhh, i can't find it, there are a lot of stuff in there. driver's side or passenger? i'm assuming it's on the block, where the water jackets are... is it below the valve covers? lifter valley?
Old Apr 19, 2003 | 07:26 AM
Bob Ayers's Avatar
Bob Ayers
temp sending unit?
Did you find the thermostat housing? The sensors should be
screwed into the intake next to the thermostat housing....
Old Apr 19, 2003 | 10:00 AM
Locry's Avatar
Locry
Unhappy temp sending unit?
uhhh, forgive me but uhhh... what does the thermo look like? is that like an elbow leading to the radiator? the truck isn't here at the moment so i 'll check later. i'm not used to ford engines...
Old Apr 19, 2003 | 10:06 AM
Bob Ayers's Avatar
Bob Ayers
temp sending unit?
If you follow the top radiator hose back to the engine, it connects
