blower heater issues
Old Dec 22, 2011 | 07:11 PM
bone1050's Avatar
bone1050
Trailering
i have a problem with my blower motor not working
it was making a noise when it was first coming on in the (dying stage) .
i was using my test light to confirm i had power going to the blower motor , since i hear the motor resistor is the most common to fail but i had no power going to the 2 wires going out to the motor itself .
so am i diagnosing the motor resistor going bad and if so where is it .
i know these parts are cheap but i want to keep this truck pretty much as much oem as i can as parts from the dealership are fricking expensive
93 f250 5.8
Old Dec 22, 2011 | 07:15 PM
dustybumpers's Avatar
dustybumpers
If the resistor is bad, the fan would still blow on high. The resistor is where the wires plug in on the heater box under the hood.
If you have been hearing the fan screech when starting, I would say it is probably locked up now
Old Dec 22, 2011 | 07:20 PM
bone1050's Avatar
bone1050
Trailering
well it was working on high so replace both but i should get power still ehh ?
maybe the fuse blew drawing to much current from a seizing fan motor
Old Dec 22, 2011 | 07:23 PM
dustybumpers
Might be. The resistors are cheap. 2 screws and out, but are tricky to get to. Blower motors aren't to salty either. Whole project will cost less than $50, and take about an hour
Old Dec 22, 2011 | 07:24 PM
White 97 xlt's Avatar
White 97 xlt
X2
If it has been screeching, another thing to watch for is a blown fuse due to the extra current draw..
Old Dec 23, 2011 | 03:12 AM
fonefiddy's Avatar
fonefiddy
Most of the time the problem is jsut corrosion on the resistor pac connection. Either clean them up, or buy a new one, and add some electrical grease to protect the connex.
The blower motor is easily lubricated. Remove the fan. Then remove the squirrel cage. You can oil the bushings, and blow out the blower motor, thru the air vent.
I just did mine yesterday.
sumbuddyloanmea.10
Jan 7, 2016 07:10 AM
superduty4x4
17
Sep 28, 2008 07:51 PM
Dodge/Cummins
Aug 31, 2008 05:42 AM
buzzer
May 17, 2004 11:01 PM
Nod
Jan 17, 2000 04:49 PM
