Hi everyone, Im new here. I just picked up an 88 F250 2WD, 5 SPD. 203,000mi, Its got some maintenance (or lack thereof) issues.
First, when I got it I noticed alot of grease on the inside of the driver rear tire. I pulled off the rim and drum today and the entire inside of everything was just covered with grease. I cant tell if its brake fluid as well, but my brake fluid level is not dropping that much, brake piston seals look ok. The other side is a little bit greasy also, but no where as bad as the other. Seems like a seal issue to me, what do you think? Which one?
Thanks!
