I'm in need of some suggestions. My 240 threw a rod today, blowing a hole in the block and oil pan. I have the Ford 3 speed manual on the column- What are some direct drop in replacement recommendations? The truck is a 1965 F100 short box that I haul a small trailer with. TRANS code A and AXLE code 09 from the data plate.
Thank you- Tom
