i need help w/84 e 350
Old Dec 20, 2011 | 06:01 PM
ford 350 nightmare's Avatar
ford 350 nightmare
it idels fine then once it warms up and your going down the road it boggs down and stalls,then starts right back up and samething happens,so while i was driving and it bogged down i switched fuel tanks and it took right off for about 5 miles then it bogged down again,i switched fuel tanks and it took right back off.This went on for about 50 miles till i got back home and i cant figure out whats wrong, i replaced the little sandstone filter in the carb and thats the only filter there is PLEASE HELP!!!!!!
Old Dec 20, 2011 | 06:20 PM
Franklin2's Avatar
Franklin2
What engine does this van have? I would try running it without the gas caps on and see what happens.
Old Dec 21, 2011 | 12:43 PM
ford 350 nightmare
it has the 460hp w/4 barrel carb
Old Dec 21, 2011 | 04:20 PM
Franklin2's Avatar
Franklin2
Then you probably have the electric pumps in the tanks, with the oil pressure switch, relays, etc. I am assuming your van is just like the trucks. There are a lot of threads in here on it, it gives everyone problems eventually. You will need to decide if you are always getting voltage to the fuel pumps or not, and check the relay and it's socket to make sure it's good, and also the oil pressure switch.
83farmtruck
22
Jan 8, 2012 06:04 PM
cleveland
41
Apr 11, 2008 04:57 PM
rdayers
Mar 4, 2007 12:33 AM
lentz321
Mar 18, 2003 07:50 PM
lentz321
Mar 12, 2003 12:56 PM
