Sponsored by: Real Truck
2011 rims on 2002???
Old Dec 20, 2011 | 12:23 PM
02sd's Avatar
02sd
Wondering if aluminum 5 spoke type 17 inch stock rims from a 2011 superduty will fit on a 2002 superduty, both are 4 x4 trucks, I thought I had read in the past that there was a clearance problem on the front because of the change to coil springs from leaf springs???? hope someone can give me some input on this, Thanks.
Old Dec 20, 2011 | 12:52 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Yes they will fit, but to get full turning you will need 2" spacers on each wheel.
Old Dec 20, 2011 | 04:30 PM
02sd's Avatar
02sd
As for full turning do you mean they might rub somewhere when you turn all the way to the right or left??
Old Dec 20, 2011 | 04:41 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Yes, they'll rub pretty badly with factory tires. You'll need 2 spacers because of the offset the 05-12's have
Old Dec 20, 2011 | 05:09 PM
02sd's Avatar
02sd
Has anyone experienced this and where will it rub, the front or rear on the frame or what exactly, just trying to get a better grasp if this will work at all without spacers as it seems like an unsafe way to go adding spacers and pricey as well as I checked on ebay and the spacers worth quite alot.
Cjisrael
Mar 18, 2016 08:31 AM
94WhiteF250
Dec 29, 2011 08:39 AM
libnsvt
Jun 30, 2011 11:03 PM
beaches
Feb 22, 2008 11:45 PM
