Quick 0-60 video with the new 306, what you guys think?
Thanks man. Depending on what truck you've got a mass air flow swap is pretty simple. Ive swapped my 94 F150 5.0 and a buddies 93 F150 5.8 over to mass air just using donor parts from junkyard trucks. Both times I got everything for around $25 at the local you-pull-a-part yard.
I guess I need to look into this further then. Mine is a '93 5.8. Obviously I'll need the sensor, hoses and the comp. I'm guessing since your saying it's simple I can use my harness with some mods? Do you know of a good source where I can find some info on the conversion?
Fordfuelinjection.com is a GREAT source if info in this...
I second the LS, just installed in my truck along with 3.55s and it made a huge difference and just as smooth as my open was. I am guessing with the 30# injectors you are running a bit rich. I am running 24# EV6's on my 347 (352....it is .060 over), and I do not need more injector unless I am running alot of wot runs on e85. I get 120% injector pulse at wot with e85, so they are static at that point, although my afrs as datalogged by my wideband are still dead on. One thing of note.....you are never really hitting 40 before it shifts..the tranny thinks it is there because of the spin and shifts. You are more like 30 as that is what your needle falls to before climbing....unless it is spinning again. Wheelspin bites. Looking good though.
Man...sounds good!! My 100K mile 302 is gutless!!!!
I've thought of building roller block and using E303 cam, but with only speed density I'm not sure. I sure do hate these AOD trannys. They suck at about everything unless you get one warmed over. My 89 doesn't have the pushbutton so you can't hold it in 2nd gear. Yuk.
Have you done anything to tune the computer on yours? Thats the whole part of the equation that confuses me on mine. Ive looked into tweecer and moates but after not understanding a damn thing i read i figured id just have it dyno tuned once i get it in the relm of running somewhat decent.
Im learning to hate my 4R70W a little more every day. Makes me miss the shift kit equipped C6 I had behind my mild 351 in my 86 f150. Granted it didnt pull anywhere near as hard as this thing does but the ability to hit second in the blink of an eye and hop the rear end up while leaving a pound of rubber on the street between shifts is something i miss dearly
Thanks for the input bud, after doing some reading and research Im thinking a drop down the 24lb injectors is the way to go. After about a decade of building carbed Ford powerplants with C6's or manuals this is my first attempt at a EFI/ computer tranny build so theres been a bit of a learning curve. Its got the 30 pounders in it now since i got the intake, injectors, and throttle body all together for dirt cheap from a buddy. Ive flip flopped between a ported stock truck intake, a gt40, and now the trickflow all with the stock 19lb injectors and the 30s. On the 19s it runs lean, on the 30s it bogs and pukes smoke with the gt40 and the truck intake. With the trickflow and the 75mm throttle body it bogs down a little bit under light throttle but runs like it does in the video when standing on it.
After tuning...my truck basically behaves like a stock truck the way it idles and drives...other than the power difference. Also check out this thread i had about tuning for more info.
https://www.ford-trucks.com/forums/1...er-others.html
Ive put a lot of consideration into going the dyno tuning route and leaving all the tuning to someone else, but the more thought I put into it the more I feel like I'd rather do it myself and learn some things in the process.
#29
Hey fellas, just thought I'd share what I've been working on. Just a 306 with GT40 heads, E303 cam, and other goodies, full description listed on the video page...
It aint the fastest thing there ever.
<iframe src="http://www.youtube.com/embed/9oLqsqV88IA" allowfullscreen="" frameborder="0" height="315" width="560"></iframe>
0-60mph - YouTube
I was even going uphill in that video!
#30
No kidding! My stock Flareside is the same speed 0-60. :P
0-60mph - YouTube
0-60mph - YouTube
Like I said its a work in progress, I'd be more then happy to blow your doors off when I have traction and a proper tune.
