Multiple Issues
Old Dec 20, 2011 | 06:48 AM
throwdown's Avatar
throwdown
Multiple Issues
Truck started some throttle issues when in reverse. Stumbled when put in reverse for just a second. Then began revving up when put in park. Threw a P0720 code (OSS) possibly. Then overdrive light flashed. Cleared codes, seems to run fine, but now the EBPV won't engage after start up. It's plenty cold out.
I have a coolant leak issue that is being resolved today. Could coolant on/in the EBPV sensor connection cause the EBPV failure?
Could coolant on the belt cause alternator issues that could relate to the OSS problem?
Old Dec 20, 2011 | 08:41 AM
mueckster's Avatar
mueckster
Where is the coolant leak? While it may be possible for coolant to contaminate the EBPS connection, I doubt it would have anything to do with the OSS, as it is location in the top rear of the transmission case.
Old Dec 20, 2011 | 11:33 AM
PaysonPSD's Avatar
PaysonPSD
These two sensors are interchangeable. Swap them and see if you get a TSS code.
EDIT: If you have a PTO tranny make sure they are the same. The TSS may be a different length on a PTO tranny.
Thoroughly clean before re-installing, including both the female and male connectors.
TSS -Turbine Shaft Speed Sensor OSS -Output Shaft Speed Sensor.
Old Dec 20, 2011 | 11:38 AM
throwdown's Avatar
throwdown
I think it's the water pump. I am up to my ears in chores and don't have time to look at it. I am having a friend of mine give it a look and I should know by the end of the day.
I'm sure you are right about the OSS, it's just that it is happening all at the same time.
The last time I shut it off, it would high idle after being put in park. Threw a P0503 code. I'm going to look it up now.
The worst part is...I had to go rent a car as we loaned our other vehicle to in laws while they visit.
Old Dec 20, 2011 | 02:35 PM
throwdown's Avatar
throwdown
Thanks Payson...Here's a thought----I have been having fuel pressure problems (varying pressure) lately. If the fuel pump is having problems, it could interfere with the VSS via the wiring harness and possibly throw the code and make the overdrive light flash. Maybe that bears investigation as well. Most of these items are original and I have about 290,000 miles on her.
Old Dec 21, 2011 | 09:48 AM
PaysonPSD's Avatar
PaysonPSD
The VSS, Vehicle Speed Sensor, is on the rear diff. You had an OSS code.
Old Dec 21, 2011 | 10:04 AM
throwdown's Avatar
throwdown
True, but I also had RPM fluctuation when going into park as well as OD light flashing. I think that indicates VSS problems, if I'm not mistaken.
I think my EBPV problem is from my serpentine belt shredding the other day. I replaced the belt but didn't look around to much and I bet it may have damaged the sensor plug or something.
Will check this PM
Old Dec 21, 2011 | 10:21 AM
PaysonPSD's Avatar
PaysonPSD
RPM is derived from the CPS signal. Seedo from the VSS.
Flashing OD typically indicates a tranny code is set, such as an OSS fault. The flashing OD is not always indicative of a bad VSS.
Old Dec 21, 2011 | 11:40 AM
throwdown's Avatar
throwdown
Update......changed OSS and ISS, no issues yet. Thanks for your help.
Old Dec 21, 2011 | 12:04 PM
PaysonPSD's Avatar
PaysonPSD
That's good to hear. Did the sensor that was the OSS have any fine metal stuck to it? It's a magnet and of course attracts wear metals and that can cause it to not sense properly.
Old Dec 21, 2011 | 12:13 PM
throwdown's Avatar
throwdown
Sorry to say, I did not do it. I was too busy (still) to get anything done. I had a friend of mine do it and as they were both original equipment from 2001, I just told him to change them both.
I will ask him though and see if he noticed.
Old Dec 21, 2011 | 12:18 PM
ToMang07's Avatar
ToMang07
Subscribing to this thread, only because my O/D light flashed the other day.
(Haven't had a chance to scan it yet.)
Old Dec 21, 2011 | 12:23 PM
PaysonPSD's Avatar
PaysonPSD
Oh well. It would have been nice to ohm them out for the hell of it, but doubt he even knows which one is which now. But if they both ohm out the same that would be telling. Hope he didn't throw them out.
If you saw it flash once no telling how many times it may have flashed without you seeing it.
Old Dec 21, 2011 | 12:32 PM
ToMang07's Avatar
ToMang07
This is the second time since I have had it... I'm pretty damn observant.
Last time though I was tooling around in a flooded parking lot....shut it off and restarted, never though much on it. (Didn't have AE yet.)
This time I was just driving. I again shut it off and turned it on, and it went away. I'll probably scan it Friday when I have some time off. We'll see... I hope it's just some stupid sensor. Drove great other than the light.
Old Dec 21, 2011 | 01:10 PM
PaysonPSD's Avatar
PaysonPSD
You should be able to use AE to find out if there is a marginal OSS or TSS. I'm sure AE can read the OSS and TSS. With the TC locked they should read the same. AE can also read TC per cent locked and the PCM uses the readings of the OSS and TSS to determone this. The OSS and TSS are also used to determine TC slippage.
I had a flashing OD light, ABS light and irractic or no speedo and that was the VSS. No SES light and at the time wasn't able to read codes.
