Differences between D44 and HD44
Old Dec 19, 2011 | 06:48 PM
JB78f150's Avatar
JB78f150
I was wondering what the difference was between d44 and hd44. I thought one was 8 lug made for f250's and one was for f150's. Can you please explain this in detail for me.
Old Dec 19, 2011 | 09:15 PM
teds74ford's Avatar
teds74ford
You pretty much nailed it. The real difference was in the old closed knuckle axles. The newer ones swap just about everything but the brakes and bearings in the knuckle.
Old Dec 19, 2011 | 10:39 PM
montana_highboy's Avatar
montana_highboy
The D44HD is rated at 3,550# and has .500" thick tubes, external locking hubs, bigger u-joints and wheel bearings.
the D44 is rated at 3,300# and has .375" thick tubes, internal locking hubs, smaller u-joints and wheel bearings.
they both share the same 8.5" ring gear and 30 spline inners/19 spline outers.
Old Dec 20, 2011 | 10:17 AM
HIO Silver's Avatar
HIO Silver
Were D44HDs high pinion, low pinion, or both? And when were high pinion D44s first available for dents? All the way through the series?
Old Dec 20, 2011 | 11:32 AM
montana_highboy
The D44HD's were low pinion only, and only came in F250's (highboys) and crew cabs....high pinion D44's were available throughout both the bump and dent series in F100's and F150's, the F250 didn't get a high pinion D44 until midyear '77 (78/79's).
Old Dec 20, 2011 | 11:19 PM
teds74ford's Avatar
teds74ford
Here's a really good website that will tell you way more than you ever wanted to know about dana 44s:
Mr.N's Dana Articles to Include 44, 60 information.
Old Dec 21, 2011 | 12:28 PM
ChaseTruck754's Avatar
ChaseTruck754
Nevermind the below - unless you want to know the difference between d44 and d44 HD in TTB axles - which is what I had in mind when I replied originally. Re-reading the above made me realize you guys are talknig solid axles (duh - this is the dentside forum!). I will leave the link below here just in case someone finds this thread in a search & could use the info.
Original post:
Here's another good one.
GoFastBroncos.com - View topic - TTB vs. THE WORLD (AKA differences between Ford TTB axles)
Bigpipes 35
Oct 19, 2023 07:15 AM
twofifty
Aug 6, 2016 10:49 AM
farmerdebruin
18
Mar 2, 2015 10:06 AM
Henrys son
Offroad & 4x4
Jan 31, 2009 03:19 AM
Navistar444
Offroad & 4x4
23
Apr 19, 2005 09:47 AM
