IDM
Old Dec 19, 2011 | 06:25 PM
Jeff68's Avatar
Jeff68
IDM
Is IDM the same as Powertrain Control Module? The book only lists the PCM. I have a 2000 F350 SD 7.3 diesel.
Old Dec 19, 2011 | 08:51 PM
F350-6's Avatar
F350-6
Welcome to FTE. No. Those are 2 separate things. The PCM (power control module) aka ECM aka computer is different than the IDM (injector driver module).
The PCM is the computer than runs the truck. It's located on the kick panel by the e-brake inside the cab. The IDM coverts the power from the truck to higher voltage to fire the fuel injectors. It's located above the driver side fender liner.
Why do you ask?
Old Dec 19, 2011 | 10:43 PM
Jeff68's Avatar
Jeff68
Having problems with my truck. Have tried other things, but keep coming back to the IDM, however, I can't find the IDM listed in the Haynes book on my truck, only the PCM.
Old Dec 19, 2011 | 11:44 PM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old Dec 20, 2011 | 01:27 AM
Robert6401's Avatar
Robert6401
Tell us what your problems are and any codes you are getting and we will get you set up. If it is the IDM that's giving you problems, I highly reccomend replacing the stock one with a Swamps High Voltage/High Frequency IDM. There is a definite difference between the two and a Swamps IDM is less expensive than a stock IDM from the dealer. There are companies out there who sell remanufactured IDMs for less, but I have not had good luck with them.
Old Dec 21, 2011 | 06:02 PM
Jeff68's Avatar
Jeff68
ok in past i had intermitten miss fire big time passenger side of engine not firing all wires have con. from 42 pin con. to injector or glow plug i get service engine soon light no codes but now i found that auto zone sold me wrong scanner my luck in the mean time i was told
from people there is no idm its built in the pcm that is wrong it is under the fender
i found it eat up its ben wet mount bolts broke off in it so i am getting a reman. for it
i changed the engine about 10,000 miles ago but the old motor had 350,000 on it
Old Dec 22, 2011 | 12:03 AM
PaysonPSD's Avatar
PaysonPSD
I hope an IDM swap cures your problem but if not it might be a burnt injector common pin on the UVCH connector. Will pass continuity check but not handle the high voltage for firing the injectors.
Click on this link UVCH Burned Center Pin
rondogw
13
Jul 11, 2019 06:19 PM
richdawg
Jun 11, 2014 10:01 PM
holas28
Feb 23, 2010 09:37 PM
c00nhunterjoe
Jan 5, 2009 07:06 PM
rgsupercrew
1997 - 2003 F150
Apr 5, 2004 12:30 AM
