Missouri Chapter Join Chapter , Leader:77&79F250
Need Help with Sons '97 Mustang
Old Dec 20, 2011 | 08:35 AM
tcbofade's Avatar
tcbofade
Originally Posted by MisterCMK
Don't shotgun parts at it. Try unplugging the CCRM and see what happens when you turn the key on. You need to determine if it is an issue with a device or with the field wiring.
+2.
You really don't want to waste $ throwing parts at it. You DO have an electrical issue, it'll take time, but it will save you dollars to slowly and carefully diagnose.
Old Dec 22, 2011 | 09:09 AM
tcbofade's Avatar
tcbofade
...and?
Old Dec 22, 2011 | 10:14 PM
spedbugy's Avatar
spedbugy
Project is on hold for the moment until we get more time to mess with it.
Old Dec 22, 2011 | 10:24 PM
Rebuild101's Avatar
Rebuild101
Was it blowing the fuse before the fuel pump went bad?
If not make sure the wires didn't get crimped putting it back together and if you used the new wire harness make sure it is wired right that may be the issue
Old Dec 23, 2011 | 06:18 PM
spedbugy's Avatar
spedbugy
We didn't replace the fuel pump. When we found out the ecc fuse was blown we replaced the PCM the fuel pump worked again. We put another fuse in it and unplugged the CCRM and tried to start it, the fuse didn't blow. We have checked the wiring as best we can and found no damage. the CCRM is inside the fender, I have no idea how to get at it to replace it.
Old Dec 24, 2011 | 07:33 PM
vloney's Avatar
vloney
The ones I've replaced, I had to remove the inner fender panel.
wirelessengineer
Nov 10, 2015 09:34 AM
preppypyro
1997 - 2003 F150
Jan 29, 2005 09:43 AM
beauprepa
Sep 3, 2004 05:43 PM
jggodfrey
Dec 21, 2003 11:00 PM
