F-250 rear end seals
Old 12-18-2011, 08:17 PM
94BigRed's Avatar
94BigRed
94BigRed is offline
Hey all
I'm ordering and hopefully installing seals on my 94 F250 tomorrow. I was wondering if anyone had some tips or tricks or could tell me if I should order anything special? What should I expect to deal with after the shafts come out? Just wanna make sure there's no secret I'm gonna miss and end up doing it again in a few days or worse.
Thanks for the help!
Old 12-18-2011, 08:33 PM
85lebaront2's Avatar
85lebaront2
85lebaront2 is offline
Old School Hot Rodder
There is a TSB concerning the 94 models regarding a mid-year change to the hub design if you have the full-floating rear. It takes a special socket on these. If yours is semi-floating then it's more like the older rear ends.
Old 12-18-2011, 09:06 PM
94BigRed's Avatar
94BigRed
94BigRed is offline
How can I check this before tomorrow and what is the difference in the seals themselves?
Old 12-19-2011, 07:23 AM
85lebaront2
There is supposed to be a mark on the end of the axles. You should be able to find the TSB on this site. I think the seals are all the improved version now, the big difference is the addition of a slinger and different inner bearing.
Old 12-24-2011, 01:49 PM
rex51's Avatar
rex51
rex51 is offline
Pumpkin removal
Hey Red,
Remember to buy or rent the special tool to remove the racheting locknut that secures the pumpkin.
Old 12-24-2011, 04:54 PM
bruno2's Avatar
bruno2
bruno2 is offline
Red, do you know for sure the bearings arent going bad. Usually when a wheel seal leaks they are being reamed out by the bearring being out of tolerance. I would do some investigating when I got it apart. Also remember to check the seals surfaces for galding and or scoring. I wont do you any good to put a new seal on a marred up seal surface.
Old 12-25-2011, 09:37 PM
94BigRed's Avatar
94BigRed
94BigRed is offline
It turned out that the piece of the brake assembly that turns the star on the auto-adjusters came loose but was still hanging by the cable. It got wrapped up and actually wore the seal itself into two separate pieces. It also wore on the face of the hub, but not where it contacts the seal, so its no problem. I got the new seals in and haven't had any problems. It did take chipping a small piece of the retainer off to determine that the driver's side threads are left handed. Donor truck strikes again.
Old 12-26-2011, 07:46 AM
bruno2's Avatar
bruno2
bruno2 is offline
Well at least you didnt have to look very deep to find the cause of the bad seal. Glad you got it fixed.
Samsn4
Ford Truck Parts for Sale
02-04-2013 04:21 PM
RipRoaringGalaxie
05-10-2008 02:05 PM
F-150Guy
06-07-2005 07:23 PM
Rancho*Ryda
06-02-2005 01:46 AM
Quick Reply: F-250 rear end seals
