Intake swap
Old Dec 25, 2011 | 07:22 PM
rickybobby1977's Avatar
rickybobby1977
Originally Posted by 73'360f100
Did you say you replaced your fuel pump if so what did you replace it with a stock one or a high volume pump.
How can u tell which is which?
Old Dec 25, 2011 | 10:51 PM
Conanski's Avatar
Conanski
Rickybobby.. your truck has a complicated fuel system on it with low pressure pumps in the tanks and a high pressure pump on the frame, and it also has a tank selector valve and fuel filter on the frame as well. For the moment however I'm gonna suggest you just ignore all that since it seems you're getting plenty of fuel to the motor, and instead concentrate on the fuel injectors. You need to get a pressure gauge on the fuel rail so you can see what pressure the system is building and also see if it's holding that pressure, because if it's not it's most likely it's because one or more injectors is stuck open and flooding the engine.
Aj-
May 24, 2017 08:19 AM
460powa
20
Dec 24, 2010 05:49 AM
dgparsons2
18
Jan 26, 2009 07:36 PM
chvyetr
Mar 28, 2006 10:29 PM
seans64'
Nov 11, 2003 12:20 AM
