frame swap
Old Dec 17, 2011 | 02:11 PM
buckethead5k's Avatar
buckethead5k
frame swap
can i put a bump side body on a dent side frame
Old Dec 17, 2011 | 03:37 PM
jowilker's Avatar
jowilker
You can, the cab/front clip are bolt hole exchange. In 73 Ford added 4" to the rear of the cab, adding length to the chassis in the bed area. You will have to deal with that using new welded in plates to use the existing bed holes.
If you will be using a flat bed no problems.
Got more questions, fire em up.
John
Old Dec 17, 2011 | 04:27 PM
buckethead5k
ok so if the wheelbase is three inches longer in 73 versus the 72. and the cab is four inches longer, does the bed need to be modified
Old Dec 17, 2011 | 05:06 PM
elgemcdlf's Avatar
elgemcdlf
Check out the tech articles at fordification.com. There is an article about doing exactly what you are asking.
Old Dec 17, 2011 | 06:30 PM
buckethead5k
COOL THANK YOU that will help
Bradtant
Dec 21, 2017 12:14 PM
red450ih
Mar 8, 2015 04:33 PM
ROBZ95XJ
Sep 7, 2014 08:57 PM
BOOboo0331
May 2, 2013 06:35 AM
olbud
Dec 21, 2005 12:23 PM
