Still can't figure out code P0308 cly 8 missfire
2003 navigator 5.4 had thrown code p0308 cly 8 misfire, replaced Cop and all plugs and also all fuel injectors, # 8 plug was a little darker than the others. After all that it still has a low rpm vibration from the engine and after driving for a few days the same code went back on.
Please let me know if you have any ideas...
I also hear a rattle occasionaly on start up not sure if that has anything to do with it.
Thanks.
Thanks.
The rattle could be a worn cat,or cat cover, is the injector ticking( power to it ,can be checked with a hose to it), does the engine change when you unplug the injector running, and or also unplugging the cop running, next any coolant loss, cylinder 8 is where the coolant port is blocked off by the intake with the gasket, its possible coolant is leaking into the intake port,or plug hole, fouling the plug, next would be compression check and valves not seating on that cylinder
I hear ya if you dont have a long piece of hose, any kind , to put against the injector and to your ear to listen for the ticking , and its hard to feel the wiring since it wraps around the back side of the intake, its even more of a pain to trace the wiring thru the loom to the pcm, are the wires on the injector red and the other light blue and you have no pulse on the light blue at the connector ,even on the back of the connector where the wire goes in the connector, or get a pin out diagram and ohm the wire for 8 like pdqford said
but i would get a injector noid light tester before i attemped all that to test for your pulse
I would make sure there was ground and no pulse before condeming the pcm for a bad injector driver, well remans are about 250 and then the install and flash from the dealer thats another 150
Could maybe borrow a good scanner or have it scanned and look at the injectors pulsing see if 8 is dead
