Excursion trans problem?
The truck starts and runs find but the check engine light is on. It backs out of the driveway fine but when you put it in drive, you can press the gas pedal and nothing happens. No forward motion, no increase in RPM... nothing.
As you're pressing the gas wonderingI can't speak civillyis wrong suddenly the thing will engage and take off.
I'll be calling the dealership about it but people here seem to know more about these things than they do!
Thanks,
Scott
Today's mail contained a notication from Ford regarding problems with the adjustable pedal assembly. The problems described are nearly identical to what I'm experiencing.
You don't need the notification. If you are having trouble, Ford will fix it right now.
Read here
http://www.blueovalnews.com/2003/tru...call.03B03.htm
