rubber gaskest for 351w
Old Apr 16, 2003 | 07:56 AM
motorcitybronco's Avatar
motorcitybronco
im doing the head gaskets on my 89 bronco with a 351w the felpro set i bought has cork intake end seals and cork vavle cover gaskets. question 1 can i use the steel rubber vavle cover gaskets that are used on the late model 302 mustang engines. question 2 where can i get molded rubber intake end seals at??
thanks
jason
Old Apr 17, 2003 | 06:11 PM
Sycostang67's Avatar
Sycostang67
You can use the newer valve cover gaskets, they are the same bolt pattern. I just did this with my wife's 79 Capri, it has a 74 302 in it and I think I got rubber gaskets for a 95 Ford.
Old Apr 20, 2003 | 07:02 AM
damtyred's Avatar
damtyred
throw away any intake end seals ya might have. clean block &intake gasket surface with paint thinner ot alcohol & run a 1/4 to 3/8 inch bead of good silicone sealer from head to head on block where seals would lay. she'll never leak
