1978 - 1996 Big Bronco
Oil Pressure Switch
Old Dec 16, 2011 | 11:54 AM
NewEnglander's Avatar
NewEnglander
Oil Pressure Switch
Has anyone changed one before? I gotta change mine, my gauge isn't working and I have no clue where it is. A quick walk through would be great.
Old Dec 16, 2011 | 04:47 PM
Captbs32's Avatar
Captbs32
This might help although it is for an earlier model.
https://www.ford-trucks.com/forums/5...-it-5-8-a.html
Old Dec 16, 2011 | 08:05 PM
bertha66's Avatar
bertha66
My sending unit for the oil gauge is on the back of the intake manifoid, but my Bronce runs a 460 engine
Old Dec 17, 2011 | 06:50 AM
b4hntn's Avatar
b4hntn
Oil pressure sender.
Ah! This is a frequent question.
First, check the connection. It may have been knocked loose during a filter change.
Remove the air inlet tube running from the top of the radiator into the air filter box. Looking at the oil filter, the sender is on the block above and slightly to the right IIRC. You can feel it, not see it. The parts stores have a socket to fit it. I recommend replacing it with a 1/4" NPT brass nipple 6 inches long and attaching a mechanical gauge tubing to it. Add a good mechanical temperature gauge while you are at it and mount them under the ash tray.
Try looking above at "Forums" and "Search" and find dozens of threads on the original oil pressure gauge limitations. With it you know AFTER you have a problem and engine damage, not before.
Old Dec 17, 2011 | 11:53 AM
NewEnglander
I found it, does the wire just pull right out or unscrews?
Old Dec 17, 2011 | 07:45 PM
Torky2's Avatar
Torky2
Push on, pull off, but you probably figured that out by now...
1990-f250
Apr 1, 2014 10:37 AM
avking2508
Mar 10, 2014 02:16 PM
bigrigfixer
1983 - 2012 Ranger & B-Series
Jul 16, 2007 05:02 PM
ejstave
Apr 26, 2007 01:12 PM
Grifzila
Oil & Lubrication
27
Oct 25, 2005 11:06 AM
