89 Ranger resistor wire???
Old Nov 5, 2002 | 02:15 PM
FH2211's Avatar
FH2211
HELP I to am having a problem with my 89 Ford Ranger 4X4 2.9L. I have spark for about 3-5 seconds at a cold start, but any time I try to after that there is no spark unless I wait for about 30-40 min. Here is a list of all new OEM parts I have replaced: the computer (EEC), ignition module( outside distributor ), magnetic pickup ( inside distributor), coil, cap, rotor, plug wires, starter relay, ignition relay, to the sum total of over $350. I have found a resistor wire, tested it, and believe that is bad (what else could it be?). So I drove down to my now very familiar auto part store ( Carquest ), just to find out that they no longer make that part. I ask you; short of replacing the wiring harness, do you know a workaround for this problem?
Any help would be a big help. Thanks in advance
Jason
Old Nov 5, 2002 | 02:55 PM
steve83's Avatar
steve83
[updated:LAST EDITED ON 05-Nov-02 AT 03:56 PM (EST)]If you know how much current the circuit draws & the resistance of the OE wire, you can just go buy a resistor & splice it in. The 89 F-Series use a 2.2KOhm, but later ones used 22KOhm. You may be able to rip one out of a junkyard harness...
Old Nov 5, 2002 | 06:28 PM
FH2211's Avatar
FH2211
A question was placed to me "Could one of the new parts that I got be Bad?" what is the chance of that? These are non-returnable.
Hmmmm.
Jason
Old Nov 5, 2002 | 10:27 PM
steve83's Avatar
steve83
Yes, ANY parts can be bad no matter how old/new/recently-working. Get a manual & test them. Then test everything else.
Old Nov 5, 2002 | 11:50 PM
brett_d's Avatar
brett_d
ford_medic
32
Mar 10, 2018 09:04 AM
BII Plow Truck
Bronco II
13
Sep 14, 2006 10:30 PM
packrat56
Nov 22, 2004 01:50 AM
jls73
Aug 15, 2004 09:40 PM
ds12
Jan 31, 2004 10:06 AM
