Dad's Truck Build
#1190
#1192
So, how's the Bronco project getting along? Or, maybe it was on the same diet as it seems to have disappeared.
#1193
#1194
Did some more work on the instruments today. The intent was to test each of the many instruments I have and pick a set that appears to be within calibration since seemingly no cluster that I have has a fully function set of gauges. Toward that end I read through the factory shop manual and found that three resistors are needed to calibrate the gauges: 72 ohm, 22 ohm, and 10 ohm.
And, since my plan was to do each instrument separately on the bench I needed a 5.0 volt supply to emulate the IVR. No prob, I have a bench supply somewhere. But, after quite a bit of searching I couldn't find it so built one with a 5 volt IC regulator capable of 1 amp.
I hooked up the first gauge with the resistor to the supply, turned it on, and watched the reading climb to almost the calibration point. And then it started falling. Turns out my regulator had gotten hot and was shutting down. Apparently it takes more than 1 amp for each of the three gauges, so I was a long way from having enough current.
Ok, let's assume the cluster I got from Trav is good and put it in. Bummer, the tach doesn't work. But, since my tach didn't work and the new one didn't work it must be wiring. So, I swapped out the wiring harness under the hood and tried again. This time as i cranked the engine it balked like it had too much timing, but then a curl of smoke went up from the positive battery cable. I think I've found what was causing the slow crank. With that replaced, and the engine cranking a lot better now, the tach still didn't work.
So, tomorrow I'll check into the dash wiring. Something must be amiss with it since 2 different tachs and two different wiring harnesses haven't worked.
And, when do you think that'll be?
#1196
Hopefully soon. I was kind of letting sit on the back burner until you got a truck or two put together out there.
You were in the middle of some pretty in depth repairs on Dad's truck. I think I have maybe another weekend or two on the rent house and a light afternoon on Whitey.
If the weather holds out I may jump on the head gasket with James.
However, I still have the degree of the camshaft,oil pan leak, changing the springs in the dizzy,hooking the tach up and the carb experiment.
There are of course a few others like the front end,but,that will probably get put off until Spring.
#1197
Trav - The wiring harness is supposed to take the tach signal, which is really just the ignition module's output, from the coil to the tach. I haven't checked to see that it is, but if the engine runs the ignition module is doing the job. But, I'll check it out tomorrow and I'll bet it is something simple. I hope.
Bruno - Does that mean you are about ready to start on another truck? A Rusty one?
#1198
His dog is going to have pups and he plans to sell them except for the one he is keeping. He should be able to make several hundred off that.
I think 3 of them are already spoken for at $200 a pop.He has money in the bank.
My problem is that he needs to be able to jump in it and finish it pretty soon. We dont live in that type of neighborhood anymore. I cant have a broke down truck on jackstands in the drive like at the old house. That was normal for that neighborhood.
#1199
If this boy will get his money straighened out.
#1200
We need to get all this mechanical stuff out of the way so we can open up Gary's Paint and Body.
I know this is going to sound funny. However, Jason as we know went to welding school. He is a residential paint contractor now,but, he went to Vo-Tech for paint and body. He knows quite a bit about body work and painting.
Our biggest obstacle is the paint booth. We need one to prime and paint. All of the other stuff can be done in a garage. A paint booth can be fabbed up pretty easy. The hardest part is finding a fan that wont ignite the paint fumes.
