Dad's Truck Build
#976
That's weird! The first paint I started with was the Ford Blue from O'Reilly's. Too dark. The second paint I tried, that shown today, was True Blue by Krylon - from Walmart. It is a bit brighter, but not bright enough. (How coincidental or bizarre is that?)
You aren't gonna like this, but I was fond of Chevy Orange. I still remember my surprise, and my mother's angst, when I painted the 348 valve covers on the sidewalk - w/o anything under them. Left quite a W in the sidewalk that lasted for years.
Got the empty cans to prove it.
I'm not good with shades of colors. I can tell red,blue,etc. but maroons and so forth still look red..
That is why I couldn't tell much difference on your shiny new engine.
Bill, I liked the Chevy orange but IIRC the 55-57 color was a different shade than the newer ones, or, that is when I started to have color problems..........Trav.
#977
...I cemented the Fel-Pro rubber gaskets to the heads using Permatex Super 300 Form-A-Gasket Sealant, and when that was set up I put a thin layer of Permatex RTV (blue, naturally ) on the top of the gasket, set the valve cover on, and ran the bolts down finger-tight. Tomorrow I'll torque them down.
I learned to glue the gaskets (I use the rubber kind) to the valve cover, and no sealant at all on the heads. Makes it easy to remove the covers for whatever reason, and it doesn't leak.
#978
So, after going around that bush a couple of times I decided on this approach since I had the time to let the gasket goo set before squeezing a bit of RTV on the top side.
#979
Dad's Truck Build.
#980
Yes, it was a truck engine, that's for sure. Wow, was there a night/day difference between the 348 and the 283. All torque and no rev vs no torque and lotsa rev. And, that's what makes a good truck engine - torque.
#982
Then I sprayed the block with the paint I thought would work and it was too dark. Another brand was closer but still too dark. Tomorrow's the last gasp - if Tractor Supply's New Ford Blue doesn't match then the engine isn't gonna match the sheet metal covers. Which is a learning experience 'cause when I build that Bee I want the engine and all the covers to be Hemi Orange. So, maybe I'll paint it from the same can.
#984
#985
Gary, I see your block is one of the strange ones with the missing "bridge" next to the distributor.
As for the color difference, I wouldn't worry too much about it. Nobody is really gonna see the block, especially after you get that giant power steering pump bracket, the water pump, the giant crank pulley, and manifolds back on.
#986
As for hiding the block, don't forget the A/C compressor - the great big horizontal one.
On the color, if TS doesn't have what I'm looking for then I'll go with what I have.
#987
It was just a matter of chance. Some blocks have the bridge, others don't. Nobody really knows why Ford did this, however it more than likely has something to do with the date the block was cast. There was probably a set time period where Ford dropped the bridge, and then brought it back a short time later, if even at all. For all we know, it could be an indicator that our blocks were some of the last ones that were cast.
Plenty of people mistake our blocks for 351C's because the Clevelands do not have the bridge either.
#988
Painted The Engine
Got the engine painted today, and used the True Blue from Krylon as both Ford Blue and New Ford Blue from Tractor Supply were darker than my powder coating. But, the pictures don't really reflect the proper color, at least on my monitors, as it is a darker blue than it shows. And, the paint is still a bit darker than the powder. Oh well, it'll work.
We are going up to see Dad tomorrow so won't get anything done on the truck, but plan to start taking Dad's truck apart on Tuesday. However, we'll take the recycle stuff to Owasso that morning since that's the only way to get that much stuff over there. So, I'll get to use it just a bit before taking it apart starting Tuesday afternoon. And, it'll probably be apart for a while.
#990
