Carburetor
Old Apr 16, 2003 | 03:47 AM
78F1504x4460's Avatar
78F1504x4460
Question Carburetor
I have an 84 302 that I just did a total rebuild on, the question I have, How do you tell if your carb is bad? I have a Carter AFB on it. after getting it back in the truck and wired up yesterday, it fired right up and ran good. I shut it off and started it back 2 or 3 more times, started and ran good. Well I went down the road and came back about 3 hours later and won't start, ain't that a *****! It has a Mallory Unilite and a Promaster coil on it, but I am pretty sure that it is firing but not getting any fuel to the cylinders. I pulled two different plugs and couldn't smell any gas, and it is in time. The engine is currently in an 85 F150. You can also stand beside it and hold the key over and within about 15 or 20 seconds you can start to smell gas without touching the pedel.
Thanks Alan
