OK, what is this?????
Old Dec 15, 2011 | 05:11 PM
tinman52's Avatar
tinman52
Welder User
I thought I had seen everything when it comes to old Fords.......but what the heck is this?? Some kind of gizmo hooked to the back of the speedo.
Looks like it had a vacuum line attached....
This is out of a '51 F-6 parts cab I'm tearing down........
Old Dec 15, 2011 | 05:24 PM
59JEEPSTANG's Avatar
59JEEPSTANG
Just a guess maybe something to do with a two speed rear.....like I said just a guess
Paul
Old Dec 15, 2011 | 05:25 PM
rbig1's Avatar
rbig1
did that truck have a 2speed rear end. switches with gear ratio prob vac. just guessing
Old Dec 15, 2011 | 05:59 PM
4tl8ford's Avatar
4tl8ford
I would vote for the two speed rear
Old Dec 15, 2011 | 06:12 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I'd vote for a governor
Old Dec 15, 2011 | 07:18 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
That's what I was thinking, but I looked up the governor in the Shop Manual, and it says nothing about anything located near the speedo.
Old Dec 15, 2011 | 08:06 PM
tinman52's Avatar
tinman52
Welder User
That was my first thought as well.....most governors I've seen have been hooked up to the throttle. Maybe it's a speed sensor??
I'll clean it up and see if there is a mfg name on it....
Old Dec 15, 2011 | 08:20 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The governor on the base of the carb is for limiting RPM, mostly with the PTO in use; I'm thinking this unit is to limit speed (not RPM) for whatever reason. Arrowhead Fred needs one of these!! Or else it is a "permissive" signal, sending vacuum to some accessory once a certain speed is reached.
Edit: I get it, I think! Rbig1 is right. With the two-speed rear axle, reading the driveshaft RPM for speed is incorrect in one of the two ratios. So when you engage the rear axle, (with vacuum, right?) it shifts gears in the speedo to show the correct speed.
Old Dec 15, 2011 | 08:24 PM
mechmagcn's Avatar
mechmagcn
It's a 2-speed transmission for the speedometer cable, so that the speedo is correct in either high or low gear in the rear-end.
Old Dec 15, 2011 | 11:57 PM
jmadsen's Avatar
jmadsen
I guess that kind of makes sense?? your sure?
. I have one on my 52 F6 with vacumn control 2 speed rear end. I can't remember off the top of my head how it hooks up to the vacumn control on the engine side of firewall though. I was just looking at mine 2 nights ago and the rubber boot deal is torn on mine. guess I need to get the other parts to it out and see if I can remember how it goes?? I think I took pictures but where oh where are they now... lol
Are you going to use it? I figure if I can ever get my F6 back together enough to drive I'll just get the rear end in high range and leave it there and may not even worry about hooking up the vacum shift control initially, at least????
Old Dec 16, 2011 | 08:23 AM
tinman52's Avatar
tinman52
Welder User
Mystery solved!!! I may play with it to see how it works....... Thanks for your input everyone!
aj64f100390-292
Feb 18, 2017 12:09 PM
Spirit of '76
Large Truck
40
Jan 16, 2017 06:03 AM
87Mater
16
Oct 18, 2009 10:15 PM
BuickTurbo
Jul 10, 2007 08:43 PM
