Blend door motor
Old Dec 15, 2011 | 01:53 PM
bill11012's Avatar
bill11012
Modular motor junkie
Blend door motor
I'm trying to get the Blend door motor out of my 98 E350.
Is there any easy way to get to it?
From everything I'm finding it looks like a nightmare to change.
Any help is much appreciated.
Old Dec 16, 2011 | 06:18 AM
JWA's Avatar
JWA
Having changed mine the motor alone is simply mounted to the side of the heater core/evaporator case, four hex-headed screws holding it in place, 8mm IIRC. The connector has a clip that needs to be released if you want to disconnect it before removal. If in doubt use a small mechanic's mirror and light to survey all this before you begin.
If you're talking about the blend door that's not as complex as it would first seem. In fact according to my 1997 E250 Ford Service Manual we need to begin by dropping the steering column and removing the entire dashboard! LOL
There are a few threads about this very topic, one or two might be under my name---a quick forum search should reveal them. Here's a link to my post about this a while ago:
https://www.ford-trucks.com/forums/9...r-problem.html
HTH
Navdriver
Nov 10, 2009 08:17 AM
why165
Nov 10, 2009 06:44 AM
Thunder Road
1997 - 2003 F150
Mar 19, 2009 05:06 PM
Help_Me!
1997 - 2003 F150
22
Feb 1, 2009 10:58 AM
Kimmig12
1997 - 2003 F150
Mar 29, 2003 12:36 AM
