testing the pip ( crank position sensor)
Old Apr 15, 2003 | 11:31 PM
gjf250's Avatar
gjf250
How do you test the PIP ( crank position sensor)? My buddy has a 1980 351 bronco ( federal truck) eec 3 ign. system. He has changed everything. Coil , ign. mod , computer, ign. relay , crank position sensor. The engine will crank but no spark until the key starter is released. Then a yellow spark will shoot across the spark plug which is connected to the coil wire. I think the ignition mod might not be sensing crank rotation. Any ideas? Thanks Greg
Old Apr 16, 2003 | 12:53 AM
steve83's Avatar
steve83
Sounds more like the power to it is coming off an circuit that's shut down during cranking, or it has a bad ground.
The Haynes manual tells how to test the PIP (Profile Ignition Pickup).
Old Apr 16, 2003 | 09:01 PM
dro man's Avatar
dro man
test it by backprobing the 2 crank sensor pins with a voltmeter set on ac voltage.A quality meter maybe required such as a fluke. I have tried using a radio shack brand for this test before and it will kill a engine that is already running. Dont remember the spec but you should see 1/2 - 3 volts cranking i think.
