Converting an older van to run on E85?
Old Dec 14, 2011 | 03:58 PM
EconolineFan's Avatar
EconolineFan
Has anyone done this? What needs to be done?
Old Dec 14, 2011 | 08:22 PM
YoGeorge's Avatar
YoGeorge
Lots of money, new electronics, new injectors. Do a google search on "convert car to E85" and you will find lots of information. In general, the lost mileage won't ever make it worthwhile to convert a non flex fuel vehicle. How old is the van? Injected and OBD I or II?
Good luck,
George
Old Dec 14, 2011 | 09:28 PM
Club Wagon's Avatar
Club Wagon
Originally Posted by EconolineFan
Converting an older van to run on E85? What needs to be done?
Pray every day & hope for miracle.
Old Dec 15, 2011 | 04:55 AM
SilverE350's Avatar
SilverE350
I think I'd rather convert to run on LPG or CNG. But even then you'll need harder valves and seats if you want the engine to last.
Old Dec 15, 2011 | 05:24 AM
EconolineFan
Good luck,
George
I actually did research it and found this site:
E85 Conversion Kits Change2E85.com
It appears the most expensive thing you need is the computer chip which is around $500? It is a 1995 E-150 with the 5.0 V8. So I am guessing OBD-I Was just wondering if anyone actually did it to their van.
WOW You really are a "jack wagon."
In Europe that is the only way to go, here it is very difficult to find an an Autogas station. Amazing how behind the US is. They push these overpriced hybrids when an excellent alternative fuel technology already exists.
Old Dec 15, 2011 | 08:21 AM
YoGeorge's Avatar
YoGeorge
Given the relative scarcity of vans, I think you'd be better off trying to find someone who has converted a 5.0 V8 of your relative vintage regardless of vehicle type. Gotta be a LOT more F150's, Crown Vics, etc. out there which would have a similar experience. Maybe try the 5.0 engine forum.
I recall OBD II was mandatory in 1996 although a few engine families converted earlier--yours is probably OBD I.
Good luck,
George
Old Dec 15, 2011 | 01:33 PM
Club Wagon's Avatar
Club Wagon
Looks like "some jack wagons" lack a sense of humor.
Could've sworn this was mostly an outspokenly antiethanol crowd & that "some jack wagons" here even resented/ridiculed the 10%-15% ethanol gas? Sorry, must be confused w/2-stroke & small motor enthusiasts.
I'm at the other end of the spectrum. Got nothing against ethanol, but don't endorse corn ethanol for fuel. Believe consumers should still have right to buy alcohol free gas for 2-strokes, small/old motors not designed for it.
IMO corn ethanol fuel suggests it's "Amazing how behind the US is." & is not "an excellent alternative fuel technology". Corn ethanol is primarily an "alternative" Farm Subsidy.
Wonder if the rosy 'Myths' section of E85 Conversion Kit website will pass "some jack wagons" sniff test? Too bad their website still shows $50 Off that ended Nov 30.
But you may be onto something linking "jack wagons" to prayer & miracles.
Old Dec 16, 2011 | 05:25 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Swap in a VW turbo diesel in there, sure will be a turd, but hey, you wanted fuel economy
Otherwise, don't complain, your driving a brick on wheels.
Old Aug 9, 2019 | 04:47 AM
Ketch347's Avatar
Ketch347
Hi from France
cause here E85 cost $2.20/gallon and the regular cost $6.35/gallon, I converted to E85 my old Dodge windows Van , 318 engine carbureted. Riding 6k miles without any troubles. Original fuel line and pump.
Modified carburetor with Rob from Minnesota, E85carb.com. It’s one way modification, can’t use again with regular gas.
after received the modified carburetor, just mounting on the engine and adjust a little. Change the timing spark with flash lamp + 4 degrees. Change spark plug to Irridium, high quality wire set and MSD coil.
the Van get more couple, more smoother and better throttle responds.
i use the Van daily . Can’t have any problem of condensation in the tank. Anyway the optional 35 gallons Dodge gas tank is make on plastic material.
the less is yes less MPG , around 20%. But with the price between E85 and regular is i win.
the less too is start cold in the winter. Do wait be warm before riding, if not engine stall.
this is my own experience.
i’ve just Purchase an 1989 E150 Club Wagon, 351w EFI. I going to modified the fuel system to work with E85 ...
Old Aug 10, 2019 | 09:44 AM
baddad457's Avatar
baddad457
Really ? In Europe they pay $6-10 a gallon for gas most of which is tax to a government who did nothing to earn that. And we're far behind ? We're a exporting oil and gas now to Europe, and we're "far behind" ? Ethanol had to be subsidized to make it competitive with petroleum based fuels and even now it's still not because it's done on a mandate from the government, and we're "far behind" ?
Old Aug 10, 2019 | 06:10 PM
maples01's Avatar
maples01
I hope you daily drive it, ethanol collects moisture, I now need a new tank for my van, and they do not make them anymore, I either have to have one custom made, or get someone to modify an available tank by relocating the fill/vent, then modify where it mounts under the van, both choices are extremely expensive. E85 is a good choice for race engines, it is cheaper than race gas, but for a regular street vehicle it is a waste of money, you will get less mileage, and will require replacement of every rubber fuel line on your vehicle too.
Old Aug 10, 2019 | 06:13 PM
maples01's Avatar
maples01
Talking
It costs more to make than it delivers, look how much diesel is used to plant/harvest it, people don't think about that, if the tractors ran on ethanol, they'd break even, would be nothing to sell after harvest.
Old Aug 10, 2019 | 06:18 PM
maples01's Avatar
maples01
After reading on a site where a guy did that to a vintage car, the results were it ran cleaner, oil had no deposits it seemed, I really wanted to do similar with my 73 but the cost, so much is needed for it, then there is the tank for the gas.
Old Aug 10, 2019 | 09:43 PM
Maillemaker's Avatar
Maillemaker
I have heard that ethanol gas is hard on old rubber fittings. Not sure if that is true or not. I'm guessing new cars are engineered with the right plastics to tolerate it, but I doubt old ones are.
Steve
Old Aug 11, 2019 | 03:06 AM
Ketch347's Avatar
Ketch347
Yes, the French State apply 80% taxes on the regular gas and Diesel. I think it's the most high level cost on all states of Europe.
Don't know if you ear something about that, but last winter here have a big big people contestation against the fees on the gasoline, named "yellow jackets"
