Actually after looking the harness over the only thing i need is the plug connector connecting the distributor harness to the ignition harness. Anyone know where to obtain this connector?
This past weekend, I came across a 1985 Bronco with 351 and C6. The engine had been picked over and the wiring was messed up, but there was the section from the distributor toward the ignition module laying there. It has three [male/female] connectors with wires still of a length to be spliced. I picked it up and you can have it for the freight, if this is what you need? Where are you located?
