ignition
Old Apr 15, 2003 | 08:20 PM
msfprobass's Avatar
msfprobass
ignition
I am wanting to change the pick-up in my distributor(84 f-150 with 77 f-150 motor). motor has duraspark 2 ignition system. I have removed armature but can't figure out how to remove roll pin. it appears that the system has two roll pins inside the shaft, both are about 1/16 inch in diameter and appear to be resting inside shaft vertically. according to the haynes manual the wire retaining clip is a snap ring but mine seems to be solid such as a washer. decided to this route instead of pulling entire distributor.
any help or suggestions will be appreciated.
hope to see everyone at the 50th annual f-100 super nationals!
Old Apr 15, 2003 | 10:09 PM
Franklin2's Avatar
Franklin2
ignition
After the retaining clip is removed, pull straight up on the wheel. The roll pin is like a key on the shaft. Just make sure it doesn't fall down in the distributor when you pull it off. Sometimes when they are stuck, you can use two screwdrivers to pry it out.
