Help needed - Engine blown :(
Old Dec 18, 2011 | 03:24 PM
Junx69's Avatar
Junx69
If you don't have any luck selling you can always try parting out. Several of us are close to you like myself and njneer.
Old Dec 18, 2011 | 04:28 PM
archtaan's Avatar
archtaan
Are you mechanically inclined enough to pull the motor? If you can get the short block to a machine shop and have it machined you could use all your existing parts to save a lot of money.
You might be able to get by finding a shortblock as well and using all your existing parts on it.
Old Dec 18, 2011 | 05:19 PM
00XLT2WD's Avatar
00XLT2WD
I am but unfortunately I don't have the room, tools, or time.
Matt
Old Dec 18, 2011 | 05:23 PM
archtaan's Avatar
archtaan
Matt
Understood. I was changing the oil on my X today and thought to myself how hard it must be to pull the engine. I am guessing grill, bumper, core support etc. has to be removed since I cant pull it from the bottom. That or pull the body. (Contemplating a Cummins conversion).
Old Dec 18, 2011 | 05:43 PM
Snowseeker's Avatar
Snowseeker
If it were mine I would try and oil and filter change first. Do you have a fram filter on there? If the problem persisted I would try a oil pump if they are reasonably priced. Then maybe start looking for a motor.
Old Dec 18, 2011 | 05:46 PM
archtaan's Avatar
archtaan
Did you check the oil to see if there was any residue or metal shavings in it? Slight knock unfortunately sounds like a bearing problem. Maybe you will get lucky and it was just some piston slap on a cold day? We can only hope. Its too close to the holidays to have a major expense like an engine overhaul.
Old Dec 18, 2011 | 05:53 PM
00XLT2WD's Avatar
00XLT2WD
I went by the dealer shortly after it was towed there. The knock was horrible and you could hear what I can only imagine is the rod slapping around inside the cylinder.
Old Dec 18, 2011 | 08:18 PM
EXCURSIONATOR1's Avatar
EXCURSIONATOR1
http://chicago.craigslist.org/chc/pts/2750930221.html. not mine but a decent one
Old Jan 17, 2012 | 06:48 PM
00XLT2WD's Avatar
00XLT2WD
Update:
I have the truck back at the house while I evaluate options. All told the dealer ended up wanting over $6000 which is more than i'm willing to put into the truck. At this point i'm debating two options.
A)Swapping out the engine with a junkyard replacement. Thanks to the help of forum members i've located a couple lower-mileage units for around $1800-2000. I don't have room to complete the swap here but could have found a couple shops that would be willing to do it for around $1200 so $3200 give or take.
B)Keeping the body and swapping it onto a wrecked donor ex. I've located a couple 2000 4wd excursions that have been wrecked/rolled. Is it ridiculous to think I could pick one of these up and simply swap my body onto the new frame? My truck is a 2000 2wd 6.8 and i've located a 2000 4wd 6.8. This might cost a little more but I really need 4wd after a recent move and if I simply replaced the engine i'd end up selling the truck and then trying to find a replacement.
Am I smoking crack thinking I can simply buy the wrecked truck and swap my body on (assuming the same year and engine)?
Old Jan 17, 2012 | 06:56 PM
ComputerCowboy's Avatar
ComputerCowboy
I saw a 7.3L PSD on Craigslist with 110K miles on it for $1,500 the other day... you might consider getting one of those instead
Old Jan 17, 2012 | 07:08 PM
00XLT2WD's Avatar
00XLT2WD
I thought about that just wasn't sure how difficult re-wiring would be.
Old Jan 17, 2012 | 10:31 PM
UrbanXX's Avatar
UrbanXX
If the engine has low oil pressure surely the gauge/warning light would have been on and you would have noticed it.
It is possible that the knock you have is carbon knock. I would look in this area. But do verfiy if the oill pressure first. I'm sure at this point you have checked to make sure its not an exhaust stud blown out.
Get a qualified second opinion at least.
Old Jan 18, 2012 | 08:17 AM
  #28
Snowseeker's Avatar
Snowseeker
Just sell it to me and buy another one.
Old Jan 18, 2012 | 08:46 AM
  #29
Treker58's Avatar
Treker58
V10
You may want to check this site, talked to one of their reps the other day and seemed like good people, at least on the phone
Used 2000 FORD EXCURSION Engine - Woodfins Guaranteed Used Auto Parts
mustangsally93
Modular V10 (6.8l)
Jan 22, 2008 11:58 AM
mustangsally93
Modular V10 (6.8l)
69
Apr 29, 2007 07:49 PM
triaxle
Modular V10 (6.8l)
Mar 26, 2004 10:43 AM
Rob51
Mar 29, 2002 10:54 AM
