Sponsored by: Real Truck
Cruise Control
Old Dec 11, 2011 | 11:02 PM
masterpuppet's Avatar
masterpuppet
Cruise Control
Hi All new guuy here. Question about CC on My F250SD when I tried to engage it today pressing both buttons it honked the horn not engaging the CC. Guessing that it is a wiring problem. with that being said what are my options here? Thanks for the help and for a great website!!!!!!
Old Dec 12, 2011 | 06:59 AM
projectSHO89's Avatar
projectSHO89
What year?
Certain button combinations can activate the horn.... This may be normal. However, there are NO normal CC functions that require two buttons to be pressed at the same time, everything ins supposed to be sequential. See owner's manual for operational instructions.
Old Dec 12, 2011 | 07:27 AM
masterpuppet
CC
my truck is a 2002
Old Dec 12, 2011 | 09:00 AM
BillyBob69's Avatar
BillyBob69
Originally Posted by projectSHO89
What year?
What he said^^^^^
You should only push one button at a time.... At least it sounds to me like you are doing two at once. Just push ON...then SET/ACCEL . Not both at once.
Now should that not be the case.....
Pull the steeing column cover and check the wiring along the top from the steering wheel all the way down to under the dash. These trucks are known for tugging on the wiring in there and causing breaks and shorts. Easy fix. Just add a little more wire.
Old Dec 12, 2011 | 06:30 PM
masterpuppet
Cruise Control
Yes i have been pushing one button at a time. With taking off the cover will I have to remove the air bag off or just undo the screws in back? Sorry for the dumb questions
Old Dec 13, 2011 | 08:33 AM
h20thief's Avatar
h20thief
Found out going to the deer lease this weekend my CC doesnt work now either. Same make and model as yours. Another gremlin to track down.
reamer
50
May 20, 2016 07:01 PM
afmedic
Dec 18, 2015 10:15 AM
1legwoodchopper
Electrical Systems/Wiring
Sep 28, 2009 08:44 AM
big poppa
98
Dec 1, 2008 08:54 AM
Rmartens
Jun 11, 2004 11:07 AM
