General Automotive Discussion
DIY: Scanning With An OBD 2 Code Reader (Video)
Old Dec 11, 2011 | 04:36 PM
ProStreetDriver's Avatar
ProStreetDriver
DIY: Scanning A Vehicle With An OBD 2 Code Reader - YouTube
How to scan your vehicle with a generic OBD II code reader to diagnose the check engine light (CEL). How the code reader operates may vary between makes and models. OBD II was used on vehicles in the mid 1990s and newer. Before OBD II was the OBD I system which needs a specific reader for each vehicle.
Once the code is found, a simple internet search using your vehicle's make, model, and the code found will allow you to search what caused the issue, and what can be done to solve the problem. The internet search allows you to search the online database through car forums, online manuals, etc to help solve the issue.
If you have solved the issue causing the fault code and the vehicle does not clear the fault code, you may need to clear the code using a code reader. Or if you hate seeing the check engine light then you can clear it, but if the problem persists, you will need to fix the issue.
btdrygulch
1983 - 2012 Ranger & B-Series
Mar 26, 2025 09:35 AM
Dimalex2
Apr 11, 2017 07:16 PM
55F250
Sep 5, 2009 02:14 AM
dkrobson
1978 - 1996 Big Bronco
Jul 29, 2008 04:41 PM
