EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
surging problem
Old Dec 11, 2011 | 03:31 PM
mrcmbenton's Avatar
mrcmbenton
surging problem
I have a surgeing problem. when driving and the truck and it starts lugging down I give it little gas and the turbo starts to spool and dumps on and off till i really give it throttle. only on light turbo boost and when the truck is lugging down. I think if the truck would just shift down a gear and not try to lugg way down this wouldnt be a problem. the truck also dumps boost under acceleration when shifting from 3rd to 4th gear sometimes. does anyone else have this problem and if so what need to be done to fix it. thx
Old Dec 11, 2011 | 04:52 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Welcome to FTE! Best to take your baby back to the dealer for diagnostic and repair.
Let us know how it goes.
Old Dec 11, 2011 | 10:01 PM
jimmyb08SD's Avatar
jimmyb08SD
Sorry cant help, but good luck and let us know what you find.
Old Dec 14, 2011 | 07:22 AM
thomastl's Avatar
thomastl
Mine has been doing it since July and 2800 miles. Ford has sent out a service engineer and verified the problem. A lot of them are doing it. Ford is working on a new calibration. I hope it is out in Jan.
Old Dec 14, 2011 | 10:02 PM
jimmyb08SD's Avatar
jimmyb08SD
What are your build dates?
Old Dec 15, 2011 | 07:13 AM
thomastl's Avatar
thomastl
Mine is 04/11. My problems:
1. Boost drop out causing surging at low acceleration when starting up hill.
2. Low fuel economy on highway. Very eratic. One time 15 - next time 17 - next time 19.
3. Transmission hard shift sometimes (it is not often but sometimes it is there).
4. Trailer Sway Control dragging brakes at highway speed and causing low fuel economy (not always but I did verify once).
Old Dec 15, 2011 | 01:34 PM
stagalv's Avatar
stagalv
Calibration; would that be just a reflash or changing a mechanical part?
Old Dec 15, 2011 | 03:16 PM
thomastl's Avatar
thomastl
New software/computer program is what they told me.
Old Dec 18, 2011 | 12:26 PM
mrcmbenton's Avatar
mrcmbenton
how do you find out when a new calibration is out?
Old Dec 18, 2011 | 12:27 PM
mrcmbenton's Avatar
mrcmbenton
Where does one find the truck build date?
Old Dec 18, 2011 | 02:44 PM
thomastl's Avatar
thomastl
I am not sure how you know when a new software mod is out. I know they will let me know on this problem and I will post here when it is out.
Build date is on the decal in the drivers door jam.
Old Feb 3, 2012 | 07:37 AM
bluebird's Avatar
bluebird
My 2012 w/1800 miles is doing this exact same thing.
Old Feb 3, 2012 | 08:46 AM
mrcmbenton's Avatar
mrcmbenton
Update on mine i replaced the turbo solenoid myself $27.00 and 5 mins and i have not had the surging problem so far. I had the kam cleard and pcm reprogrammed be fore i did the replacement and that didnt work. I was also noticing the turbos dropping boost between shift points more often and now hardly at all.
Old Feb 3, 2012 | 08:49 AM
mrcmbenton's Avatar
mrcmbenton
I still think ford needs a new shift program for these rigs i dont like how they lug way down before shifting
Old Feb 3, 2012 | 08:59 AM
bluebird's Avatar
bluebird
Mrcmbenton, why didn't ford fix the solenoid for you?
I had a 250 diesel and a 5.4 and they both bogged. Both were 99's.
