fog lights
Old Dec 10, 2011 | 03:42 PM
dmanshane's Avatar
dmanshane
fog lights
ok i have a 2000 xlt f350 it does not have them ford fog lights in the bumper like most do has any one added them to their pickup any part numbers for factory ford fog lights brackets lights ???? help i want them i am buying a ranch hand legend front bumper replacement and they have a cut out for the lights so i want to get some put on they dont have to be wired in to the switch that pulls out i know how to wire them just need part numbers to mount bracket and lights them selves is there any where on line anyone knows to buy the stuff ???
Old Dec 10, 2011 | 05:30 PM
Supercab's Avatar
Supercab
Can you please slow down and tell us more plainly what you are wanting to do-Thanks!
Old Dec 10, 2011 | 05:38 PM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
Rather than get Ford OEM fog lghts why not just get some aftermarkets that will work best with the new bumper? You can probably get better for the same price as OEM.
Old Dec 10, 2011 | 05:59 PM
dmanshane's Avatar
dmanshane
ok i had alot going on
i have 2000 F-350 XLT i does not have factory fog lights i am wanting to put them on i dont have to wire it into the headlight switch like the factory i can put on other switch. any place online where i can buy the oem ones and the mounting for them i dont know anyone locally that has a ford with them lights i can look at so see exactally what i need i know you can add more i have seen up to four of them lights in that opening
Old Dec 10, 2011 | 06:03 PM
SpringerPop's Avatar
SpringerPop
Why not look into #4509 bulbs? They're a PAR36 sized bulb, and will fit any standard PAR36 housing for 4-1/2" diameter bulbs. That would be most tractor headlight housings, etc.
They are NOT a substitute bulb for the OEM fog light fixtures at all. However, the PAR36 fixture and bulb is about the same physical size as the factory fixtures, and they should be able to mount in the same location.
100 watts, parabolic reflectors, VERY-good performance, though not legal.
They're aircraft landing lamps, and they are BRIGHT!
Oh, wait a minute! Did I just suggest something untoward?
Pop
Old Dec 10, 2011 | 06:05 PM
dmanshane's Avatar
dmanshane
ok there is a smart idea my grandpa put them on his tractor but i think i would use them more as a spot light but where to buy them ???
Old Dec 10, 2011 | 06:07 PM
dmanshane's Avatar
dmanshane
4509 BULB - 100W PAR36 SEALED BEAM
an adverage live 11 hrs ???
Old Dec 10, 2011 | 06:42 PM
SpringerPop
I didn't say they lasted forever.
I said they were BRIGHT!
Pop
Old Dec 10, 2011 | 07:05 PM
dmanshane's Avatar
dmanshane
Ok I need something that lasts and is bright something like a John Deere hid Off of a 8rt series but they about 350 or more
Old Dec 10, 2011 | 07:58 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
I have a set of OEM fogs waiting to go on my truck I'm tiring to decide weather to go with a 9005 or a 9006 bulb, they each take a different plug so what ever one I Chose I am going to make my own harness and get the plug at this place.
Innovative Wiring - Headlight Parts
Old Dec 10, 2011 | 08:01 PM
dmanshane's Avatar
dmanshane
where did u get the oem lights ???
Old Dec 10, 2011 | 08:06 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
I got them off a fellow member on here that did a 05 grill and bumper upgrade. Let me see if I can remember some of the places I look and I will get back to you.
Old Dec 10, 2011 | 08:14 PM
dmanshane's Avatar
dmanshane
Replacement F107521 Fog Light | Auto Parts Warehouse
i found them do u think they are close enough ?? i know it says it dont fit an xlt but does for liariat
Old Dec 10, 2011 | 08:27 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Yea they will with a small little mod where you put a small little piece of sheet metal along the top back of the bumper for them to bolt to. and don't forget there is a driver side and a passenger side so you will have to get one of each.
Old Dec 10, 2011 | 08:32 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
here's a wright up a fellow member did just a few days ago.
https://www.ford-trucks.com/forums/1...1999-f250.html
