Just Bought 97 F250 460CID
Trust me I have a hard time believing I got 16.7. It was only a 90 mile trip but I made the trip 2 times but its a enough times.for me to believe its getting that. I did a couple of trips that were 320 miles on mostly interstate and that was like 14 or so mpg. Still not bad considering I don't have cruise.
Exactly how did you calculate the mileage of the 90 mile trips?
My 0.02 USD worth . . .
My F250HD 4X4, 460/E4OD/4:10's and a Drake Welding lumber rack for reduced aerodynamics gets 7.5 mpg around town and 10 on the highway.
I'm sure a great deal of that lousy mileage is the tall stance and lumber rack. Oh well, it's a real man's work truck, not a mall cruiser.
YMMV
Ray
YMMV
Ray
It wasn't exactly 90 miles but close. whatever the distance I drove from the gas station to the next then divided it by the fuel used.
Well i looked back and I did advance the timing to 12. So i think the timing was at 14 for stock
so you retarted your ignition timing back to the factory 10* and your getting that good of mileage?
Stock timing is 10 (ten) degrees!!!! Period!!!!!! I have no idea where it was before you moved it....
Doing your mileage based on a 90 mile trip is NO way to check it. You need to fill your tank and then make that 90 mile run untill your tank is about empty and then fill it up then do you division and see if you are still getting that 16.7mpg,I am betting not. I have a 92 with the 5.8 that I bumped the timing to 12 on it and I still only get 12-14 average. I'm not calling you out I just have a hard time accepting that a 460 is pulling that kind of mileage, and if it truly is then start a thread that shows how you have your truck tuned so more guys can get that to.
so let me make sure im not "confused" again. you fill up, drive 90 miles and are sitting on a half a tank of fuel?
ok so your telling us that you got 16 mpg on a 90 mile trip and when you returned from this trip you had a half a tank and you filled it completely up to check your milage. if this is true you either 1. have a gas guage that is lieing its tail off. or 2 you have a 11 gallon fuel tank.
i did the math and if you used half a tank in 90 miles that means at 16.7 miles per gallon you would have used 5.3892215568862275449101796407186 gallons.
