tachometer help
Old Apr 15, 2003 | 09:46 AM
aball73's Avatar
aball73
tachometer help
The tach reads no less than 2500rpm. It will go to 0 when engine is off. The tach does register higher under acceleration. Any ideas on the problem and fix?
Old Apr 15, 2003 | 11:38 PM
steve83's Avatar
steve83
tachometer help
Does the needle move as you go from idle to 2500RPM, or is the engine actually idling at 2500?
Old Apr 16, 2003 | 08:41 AM
aball73's Avatar
aball73
tachometer help
The enigine is not idling at 2500. It does move up under acceleration. 2500 is just the lowest it reads. I am thinking that it might be a bad sensor in the distributor. I am not familiar with how the tach hooks up to get the rpms.
