Leaky power steering question
Old Dec 8, 2011 | 12:24 AM
Plain Jane's Avatar
Plain Jane
about once a month, always on a twisty narrow dirt road at low speed a bleeder is opening up and let a bit of PSF out. I am going to buy a new steering gear box.as well as a new pressure line and return line. Are there any other connections/lines in the system that could be the issue? or should this pretty much do it
96 F150 302 4x4.
Thanks
Old Dec 8, 2011 | 01:17 AM
pnp522's Avatar
pnp522
I replaced the pump, lines, and steering box and this still happens on my 93, especially after going slow on really twisty dirt roads.
Old Dec 8, 2011 | 04:18 AM
cj06's Avatar
cj06
some trucks have a cooler on them that can leak , dont know if yours does though !
Old Dec 8, 2011 | 11:15 AM
Plain Jane's Avatar
Plain Jane
I'll have it up on my buddies lift next week for an install of: all the new PS system parts I mentioned, new front hangers for the leaf springs and a few hours of undercarriage cleaning followed by POR 15, I'll check for a PS cooler when its up. Thanks. We're also replacing the original 16 year old distributor cap with a new MSD & rotor as well as some mallory 300 ohm wires. And, of course, an oil change.
BTW If I do have a cooler where would it be? My leak is directly on top of the steering gear box, I originally thought it was the bleeder on top of the box but it might be the two fittings where lines attach, those are pretty saturated with PSF as swell.
Thanks again!
Old Dec 8, 2011 | 11:37 AM
bobbyjo9's Avatar
bobbyjo9
The cooler is just a length of hard line with bends attached to the cross memeber that runs under the pan. Its basically a long return line
Old Dec 8, 2011 | 12:07 PM
pnp522's Avatar
pnp522
There are also 2 different return lines. The regular one and one with a longer metal section that came on the towing package.
Old Dec 8, 2011 | 01:09 PM
Plain Jane's Avatar
Plain Jane
Sounds like I need to take a few measurements and verify shape before I purchase. Excellent piece of info. I just clicked on your heart Icon for cred.
Thanks again
Old Dec 8, 2011 | 01:13 PM
Plain Jane's Avatar
Plain Jane
@ Bobbyjo9 I just added to your rep too. I do have the longer return line, I remember wondering what purpose it served when I was under the truck, now I know, thanks!
Old Dec 8, 2011 | 01:37 PM
bobbyjo9's Avatar
bobbyjo9
cool.. glad ta help
Old Dec 8, 2011 | 02:39 PM
cj06's Avatar
cj06
some fittings on pumps use a O-Ring for a seal and it could be bad !
Old Dec 8, 2011 | 03:54 PM
SideWinder4.9l's Avatar
SideWinder4.9l
I've had a 1994 XL, 300/E4OD/3.08 and a 1992 XL Custom, 300/M5OD/3.08's...Both were 4x2...And both had the long powersteering pump hose...High Pressure side....
And I hardly think either one is a "Tow Pkg" truck...lol
Old Dec 8, 2011 | 04:01 PM
danr1's Avatar
danr1
Return line "cooler" rusted through at one point three or four years ago, I cut off the bad section reconnecting rubber line to it.
Here this fall got it out making it ready to plow only to find the line up at the gear box rusted through a small pin hole, can't just cut it off be nothing left clamp hose to.
Bought a brass barbed hose fitting that screws directly into the GB, it is flared just like the line it replaced. It works perfect no leaks, just a 1.5" section of rubber line run from GB to pump return port.
No rubber doesn't provide much in the way of cooling but it doesn't rust either!
Old Dec 8, 2011 | 04:05 PM
pnp522's Avatar
pnp522
If you go to rockauto.com you can see the differences in the 2 lines
SideWinder4.9l
Nope....Just will rot/crack and fall apart.....
Not being a dick, but simply fixing it the right way, can cause a LOT less issues....
Not to mention, could keep you from hurting yourself/someone else....
Old Dec 8, 2011 | 04:15 PM
Slip ford man's Avatar
Slip ford man
I used a small coil of 3/8 copper line from Home depot, was cheap and easy
