Brakes vs. Vacuum
Old Apr 15, 2003 | 08:12 AM
billman's Avatar
billman
Brakes vs. Vacuum
I recently noticed this after a recent job from the local dealership.
My brake pedal slowly goes to the floor and when I release it, the idle of the truck goes up and then settles back down. Do you think there is some sort of vacuum leak around? The truck does have a slightly shaky idle, rich smelling exhaust, and poorer gas mileage after the last job (they replaced a cracked exhaust manifold and an oil pan gasket).
Old Apr 15, 2003 | 11:35 PM
steve83's Avatar
steve83
Brakes vs. Vacuum
Yes, that sounds like something the dealer should have noticed before any repairs. Since he didn't (or didn't point it out to you), it's now his problem. I'd take it back & make them fix it free.
Old Apr 16, 2003 | 07:35 AM
billman's Avatar
billman
Brakes vs. Vacuum
Thanks steve83,
Anybody else with other thoughts out there? I would like to try and isolate it before I take it back.
Old Apr 16, 2003 | 01:52 PM
gasman6674's Avatar
gasman6674
Brakes vs. Vacuum
Plug off the line going to the power brake booster and see if it makes a difference. My sister in law had a rustcort (escort)
with a bad booster and it would die when you pushed the brakes.
Hope this helps
Old Apr 17, 2003 | 08:22 AM
billman's Avatar
billman
Brakes vs. Vacuum
I disconnected the booster and plugged the line, but no change to the idle (still a little shaky and slight hesitatation on quick throttle). Vacuum at idle stayed between 19" and 20", but went down to 0" on quick throttle instead of around 2".
Also, I applied about 10" of vacuum to the booster and lost about 2" over 10 minutes- not sure if there is a slight hole in the diaphragm, but I guess it is possible.
