Electrical Grimlin; need some help
Old Dec 8, 2011 | 08:45 AM
OldStyle's Avatar
OldStyle
Rusty Roller
Looks like the headlight switch gets it's power directly from the wire connected to the starter solenoid; battery side. Doesn't go thru the fuse box. So you need to follow the advice above and back trace the wiring to find out where it has been cut and re-routed. Looks like it is wire #25 bk/o. (I think that's black&orange) Page-01
Old Dec 8, 2011 | 09:01 AM
ctubutis's Avatar
ctubutis
The headlight switch has a built-in circuit breaker as the headlights themselves are not powered by the fuse panel but are, as mentioned, powered powered directly by the battery.
The tail lights, dash lights, running lights, etc. all are fed by the fuse panel.
Old Dec 8, 2011 | 04:13 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
I checked the wire on the solinoid that has the fusible links and they getting power. Let me look at the diagram...don't know much about diagrams lol
Old Dec 8, 2011 | 05:02 PM
ManfredVonRichtofen
On the instrument panel fuse, I took the fuse panel off the firewall and looked on back and there is a blue w/ red strip wire on both terminals...I followed one of the wires to my steering column which looks like goes to the light switch for the gear selector.
Old Dec 8, 2011 | 05:06 PM
ctubutis's Avatar
ctubutis
Light blue/red-stripe is dimmable backlighting used in the gauges, radio, HVAC controls, etc.
Old Dec 8, 2011 | 05:39 PM
ManfredVonRichtofen
I found a black w/ orange strip wire in my engine compartment, looks like it had a fusible link but looks like the wire broke...what now?
Old Dec 8, 2011 | 05:49 PM
ManfredVonRichtofen
HOT DAMN...I just hooked a wire from the battery to it..cut off the fusible link to check what it was and pulled my switch...and booyah!!!! THEY CAME ON! HOLY FUDGIN ****.....
Do I need to install a new fusible link and wire it to the solinoid?
Old Dec 8, 2011 | 09:36 PM
ctubutis's Avatar
ctubutis
I would.
Old Dec 9, 2011 | 06:11 AM
OldStyle's Avatar
OldStyle
Rusty Roller
Originally Posted by ctubutis
I would.
2x on that.
Old Dec 23, 2011 | 03:32 PM
ManfredVonRichtofen
Ok, I've still have no figured out the blinkers, stop lights, etc.
I've got 4 wires that were cut (Yellow, Green, Black, and looks like a Black but maybe it is Brown?)
What goes to what?
Old Dec 24, 2011 | 08:32 PM
ManfredVonRichtofen
Anyone know what them wires I mentioned above go to?
Drewpier
Large Truck
Oct 13, 2016 07:38 PM
.:1978_Ranger:.
Oct 9, 2014 09:54 AM
march
Feb 3, 2013 10:31 AM
thebigcheese
Aerostar
Jun 26, 2004 03:50 PM
